Question about Gateway (4000274) Motherboard
Can't find driver for onboard agp chip, also can't get to recognize a video card. running win 98 or winme.
How can search my rosh mother board vga driver
Posted on Sep 06, 2009
I have a NEC versalpro - PC-VY13M/RF-U laptop(win xp pro.) without any drivers. I find them everywhere that i could. But negative. pls help me if you can.
Have you tried
http://www.dmmdownload.com/current_html2.php
[SKU :- S60AGP] AMD ATI Radeon™ 7000 DIAMOND STEALTH S60 AGP 32MB DDR TV Out
[ DISCONTINED ]
DOWNLOAD OS TYPE VERSION DATE CONTENT bullet_submenu3.gifDOWNLOAD - [37.03 MB] WIN-XP WIN-2000
DRIVER VER DMM 3-0 2008-06-17 Driver Update bullet_submenu3.gifDOWNLOAD - [9.70 MB] WIN-98SE WINME
DRIVER VER DMM65 8-203 2008-02-03 Driver Update
Jul 02, 2011 | ATI RADEON 7000 PCI Graphic Card
VGA driver for Windows 7
There is no driver for such an old onboard video chip, it simply doesn't support Win 7 so it runs on the basic VGA default driver.
Get a separate AGP video card , whatever you get, no matter how old, will be better than what you have now.
Jun 06, 2010 | Biostar P4TSV INTEL 865G Motherboard
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
Comp will not recognize my agp radeon HD2400 pro graphics card
Try the following : Go into the setup routine using the onboard video. Go to the  Intergrated Peripherals.
Find the onboard video and change it to disable. Save changes.
Change monitor to the AGP card.
  I hope this helps.
Here is a web site for your Award Bios setup:
http://www.buildeasypc.com/sw/bios_setup.htm
Inegrated Peripherals
This menu allows you to change the various I/O devices such as IDE controllers, serial ports, parallel port, keyboard etc. You can make changes as necessary. See figure 5.
Dec 19, 2008 | Biostar P4M80-M4 Motherboard
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
ECS M925 MoBo onboard graphics
Well it all depends on if the onboard is fried. Usually, that's a sign of overheating. I'd toss in a case fan. Maybe try running the system with the side of the case off of it. If it still does this try putting a fan beside it to give it a massive rush of airflow. If it stables out, then it's a heat issue.
You can put an AGP card into that motherboard, which is always beneficial to the performance since the processor and RAM isn't being used by the video. However, you'll need to disable the onboard video system in the BIOS before you can really use an AGP card to it's ability.
I hope this helps bud.
Sep 20, 2008 | PC Chips (M925G) Motherboard
Video card makes system unstable
Hi Wayne, it's rule of thumb to always uninstall the old software from add/remove programs before installing the newer software drivers. The reason for this uninstall is so the two programs do not over-write files with the same name.
The ASUS P4S800-MX motherboard does have an onboard graphics card, (SiS Real256E). If you added another video card into the AGP slot & did not disable the onboard graphics, than you're AGP card will not run correctly. (I'm suprised it even loaded)!
Please read page 2-19 in you're motherboard manual to help fine tune the bios when using an AGP video card. Than go to page 2-21 & than set, Primary VGA bios to; [AGP,VGA Card]. Save & exit. The PC will restart.
Press & hold the power on button on the case. This will power off the system. Unplug the power cord from the power supply. Insert you're AGP card & make sure it is fully seated. Close the case & plug in the power cord. Boot up the system. Uninstall any other software you did install for the AGP card. Retsart the PC after uninstall is complete. Install the latest software you downloaded for the AGP card. Restart after install is complete.
Lastly, run windows update service & choose ustom, not express. Check for hardware & software updates. You're system should function much better & when you check the system properties you will find you have more system memory. This is because the onboard video used you're system memory to run.
Good luck Wayne!
Mike
Jun 25, 2008 | ASUS P4S800-MX Motherboard
ATI 9600 xt problems
Hi, Im guessing that your motherboard has an intergrated video card & you installed the 9600 card into the opened AGP slot on the board. If you would have listed the model number of your motherboard I would't have to guess. What you need to do is enter your bios & make a change so your bios loads the AGP slot & not the intergrated video card. How to get into your bios? As soon as you turn on the Pc press the Delete key every two seconds. If your system fails to load the bios than you will need to try some of the others F keys. Let the PC finish loading. Re-start the PC. As it starts up try the F1 key every two seconds. Continue in this manner using these other F keys untill your system boots into the bios. F2, F10 or F12. One will work for you. Once in the bios use your manual if you have one. You are looking for Video display. You want the bios to load the AGP slot first, this will disable the intergrated video automatically. Your Pc will now see your 9600 video card & you will be able to load it's software. If the 9600 uses ATI's software you should update the Radeon software by going to ATI/AMD & update your video software with the latest drivers. Click the link I have posted below to upgrade your Radeon 9600XT card. Good idea to save the link.
http://ati.amd.com/support/driver.html
Fill in the needed information to get to your driver software.
If your using Win XP Pro or Home click here:
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
Feb 19, 2008 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
Video card troubles
Hi, with my own Foxconn mobo [661FX7MI] I had to run the installation disk that came with the motherboard and reinstall the AGP driver. Then run the AGP card driver [ATI]  disk.
Regards mistyman
Oct 20, 2007 | Foxconn 760GXK8MC-RS Motherboard
Gateway (4000274) Motherboard Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
