Question about Garden
We have a porter cable power washer Model PCH2627, we are down sizing and would like to sell this item., do you have any idea what the cost of this was new? Cannot find receipt.
2 Suggested Answers
  • 760 Answers
SOURCE: engine manual for the Porter Cable pcv 2250 pressure washer
If you need an engine manual, then look up the manual on the engine manufacturer's web site. eg Briggs & Stratton, Honda, Techumseh. Porter Cable manual would just have cart and pump info.
Posted on Jul 23, 2010
Rebuild porter cable framing nailer
This model suffers from cylinder seal failure (large plastic seal sitting on top of cylinder) and sticking headvalve. Easy to fix however. Remove head and pop out the headvalve . Lube the headvalve orings with white grease and reinstall. Replace the plastic cylinder seal with Ridgid seal #079020001013, same part as porter cable but cost less. Good luck
Jan 09, 2014 | Porter Cable Cable No. FR350A Rnd Head...
Need a power cord for a porter-cable circular saw model 146
All of Porter-Cable's circular saws have model numbers starting with a 3. Assuming your saw is a 346, Porter-Cable's part number for that cord is 330079-98. If your model number isn't 346 or you can't get that part number, most any nine to twelve foot 14-2 power cord will work on your saw.
Feb 24, 2013 | Porter Cable Saws
My porter cable 200 psi air compressor will not run
The curcuit breaker on the motor. Probably a little round button that's about the size of a screw head.
Jan 04, 2013 | Porter Cable Air Tools & Compressors
Are the 7 degree dovetail bits, that come with the jig, the only size that can be used or can a 9 degree bit be used?
Hi, W/D at your service.
Apparently, there are several types of bits compatible with your model.
Here's a link that gives you a better idea:
http://www.toolup.com/porter-cable_4216_12-deluxe-dovetail-jig-combination-kit.aspx
Best regards, --W/D--
Feb 23, 2011 | Porter Cable Porter-Cable 4216 12" Deluxe...
Engine manual for the Porter Cable pcv 2250 pressure washer
Jul 23, 2010 | Porter Cable Cable Commercial Pressure...
Hot water coming out of a cold water pressure washer
This sounds like a heat transfer problem
You should check that the oil reservoir for the pump has oil in it. It sounds like it may be low. Also, if it is a gas model, the engine oil may be low.
Remember the pump oil reservoir should be only 1/3 to 1/2 full of non-detergent oil.
Aug 10, 2009 | Porter Cable Garden
Wobble in disk
if this is disk type grinder make sure you did not knock the disk out of alignment when it fell off table if so remove and re-align or replace disk seen it before make sure
Nov 24, 2008 | Porter Cable Porter-Cable Variable Speed...
Will a Porter Cable 7312 offset base laminate trimmer also work on Model 7301 HD POWER UNIT
I think it's meant to fit the 7310 trimmer, as the series numbers are in sequence. But when I look at the parts list for the 7301 & 7310, they seem to have the same motor housing part number, which indicates they are more or less the same size, no?
Check at the following website, http://www.dewaltservicenet.com/SearchResults.aspx?q=laminate%20trimmer
They also provide the means to ask them a question, if you're not sure you want to risk returning an order, in which case you want to link:
http://support.dewalt.com/cgi-bin/dewalt.cfg/php/enduser/ask.php?p_sid=tZeaxJtj&p_accessibility=0&p_redirect=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xNzM4LDE3MzgmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0x
I hope this info allows you to sort it out.
Sep 01, 2008 | Porter Cable Porter-Cable 7311 Offset...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
