Question about Westinghouse SK-26H590D Television
Hello.\r\nMy Westinghouse SK-26H590D completely
Hello. My (14 month old) Westinghouse SK-26H590D completely stopped working for me last night in the middle of watching a program. At the same time, my Comcast HD box displayed an error message "DV1". Also at that time the light in the built in DVD slot was illuminating different colors every few minutes - orange, violet, amber, blue (standard color when powered on), but I still couldn't receive any picture. I removed the HDMI cable for a few minutes, and had Comcast send a Reset signal to the box. The cable box is now working normally, but I now cannot get any signs of life from the TV (even with the HDMI cable disconnectd). The TV appears completely dead at this point. Any suggestions?
Thanks.
  • viperbar Sep 08, 2009
    Thanks for your help.
    I will bring it in to have the repair made.
    Atr least I know what to tell them needs to be done.
    Hopefully this will ensure they don't try to overcharge me!
    Thanks again!
  • 3,741 Answers
You are not the only one facing this problem.there are many users facing this same problem in this model and brand of tv. this problem occurs when the 2200 micro-farad capacitor on the power supply gets shorted the tv gets completely dead. ------------- a defective 2200uf Capacitor on the power supply board. Take a look at the top of the capacitor it will be either buldged at or will look bit burned on its body. ---------- the cost of getting this done by a technician will cost you near to $100 including the capacitors cost. ---------- you can get this part at www.shopjimmy.com and the other is www.discount-merchant.com if you are familiar with opening the back of tv and removing the main board and then soldering the capacitor you can do it manually but its a long and tough procedure. ------- technicians help is advisable.but replacing the capacitor will solve the problem.---- this will help. --- thanks.please keep updated.pleasedo rate the solution if helped.thank you for using fixya.
Posted on Sep 06, 2009
Does sk-26h590d have HD connection
It might have a built-in HDTV tuner or it may require installation of an HD converter box. If you see decimal channels such as 3.1, 29.2, etc. you have an HDTV tuner. If you see channel numbers without decimals such as 3, 29, etc. you will need to install a converter box
Dec 27, 2012 | Westinghouse Electric SK-26H590D 26 in....
MY REMOTE NO LONGER WORKS MY TV BUT THE BUTTONS ON THE SIDE DO WORK
Have the actual remote itself tested---most shops will do it for free--if remote is bad you know and if tests good suspect the remote receiver in the set on the front is bad.
The last possible reason is some sets have a lockout feature that disables the remote feature inside the TV---not real common but no unheard.
Sep 04, 2012 | Westinghouse SK-26H590D Television
My Westinghouse 26H590D widescreen with DVD combo all of a sudden is messed up on color. It seems like the red is gone so human lips look blue, what I know from other tvs should be red come across yel
Looks like some dry solder, dry or leaky capacitors in board. Anyhow, first of all check and ensure that your input device, cables, connectors and jacks are ok and there are no loose contacts. Try working the TV on a DVD player and see. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Westinghouse SK-26H590D Television
Owners manuel for westinghouse tv sk-26h590d
Hi Chuck,
You may download Westinghouse SK-26H590D User/Owner's Manual at this link (www.retrevo.com). When you are on the link, click "Download the Document", enter your email address and confirmation number, and then click "Download Now" to automatically begin the download. Manual is in Pdf file format, you must have an Adobe Reader to open the file. Just in case you don't have it yet, click this link to download and install it to your computer. After the download completed, run the set-up and then follow the wizard. The links I've provided are safe website, I used it personally.
Hope I helped you.
Have a nice day!
Kind Regards,
Jdvillanueva
Dec 19, 2011 | Westinghouse Televison & Video
About 8 months ago, every time I turned on the TV (SK-26H590D), only vertical lines would appears... almost like watercolor: green, orange, etc. However, you could hear the channels and change them as...
Hello
Get into Menu Operations and come to the window video reset. You can get this in its manual section [1-6]. Reset all video sub menu items to factory reset. Check out after this reset process whether the problem solves or not. If not its video card has some trouble. Contact
www.westinghousedigital.com and enquire them about the nearest westinghouse Authorised Service center of theirs to you. Thy only can set it right. OK.
May 08, 2011 | Westinghouse SK-26H590D Television
My Westinghouse SK-26H590D widescreen dvd combo won't play dvds.You can insert one but it will display "no disk".2 disks were jammed in the dvd slot and were removed(kids).I have a feeling it must have...
Most likely the laser lens was damaged when the 2 disks were jammed in. You must open the tv and check the status of the laser head and its lens, if it's faulty it will have to be replaced. Fortunately this is an unexpensive part.
Jun 05, 2010 | Westinghouse SK-26H590D Television
When I turn on my Westinghouse SK-26H590D with the remote it powers on I get a black screen with "VGA No signal" then after a few seconds it turns off and there is orange coloerd light instead of blue
This one might be a settings issue but I need more information to help you resolve this issue, please send me a bit more details or your contact information at westytech@wde.com so I can better assist you with this issue.
Nov 12, 2009 | Westinghouse SK-26H590D Television
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Televison & Video Logo
131 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
