Need to replace suction cup on bottom of old fashioned rotary salad grater Where could I find such an item?
    President:
  • 3,085 Answers
I would look in some Marine / Boaters Supply Stores, Kitchen Supply Stores or on eBay.
Posted on Sep 06, 2009
Salad Master Coffee maker. How much coffee for each cup? Also how do I keep grounds out of coffee? Thanks Aimee
A machine like the one in the link? That is an old style percolator. Mother had one when I was a kid. I am 63!
You will see in the diagrams that a filter paper is being used. With mother's the bottom of the strainer was fine so you didn't need one. Use a standard bowl type filter and if you can find circular filters with a hole.
One heaped dessert spoon is two cups. Supermarkets have a measure for sale.
Salad Master Coffee maker Google Search
Dec 19, 2016 | Coffee Makers & Espresso Machines
Tip
How to repair/reuse plastic suction cups Plastic suction cups are used in many...
<p>How to repair/reuse plastic suction cups<br /> <p>Plastic suction cups are used in many applications to hold things to hard smooth surfaces like glass, ceramic, laminate, metal, plastic, etc. With time the suction cups loose their holding (suction) strength due to hardening or deterioration. Before trashing and/or spending cash try this if you want a permanent or lasting installation. <br /> <p><span><span>1.<span> </span></span></span>Place the item in the position you want it to remain installed. Make matching marks to ensure that is were you want the item installed. Mark a dot in the center were the suction cup is to hold.<br /> <p><span><span>2.<span> </span></span></span>Clean the old suction cup suction face and mating surface thoroughly, ensure there is not grease or contaminants.<br /> <p><span><span>3.<span> </span></span></span>Apply a thin coat of urethane base all purpose adhesive such as UHU, Liquid Nails, etc. to the suction face and mating surface (do not use cyanoacrilates such as Super Glue or water based glues, they are too hard or too weak for the job).<br /> <p><span><span>4.<span> </span></span></span>Wait approximately 15-30 seconds for the adhesive dry to touch and press or install the item with suction cups at the desired location using your matching marks as guides. Keep the pressure for a few seconds to ensure good bonding. Once installed wait for at least six hours for the adhesive to completely dry, before loading or applying weight to your item if it is a hanger or shelve.<br /> <p><span><span>5.<span> </span></span></span>This should do the trick. If you need to disassemble your item in the future you may peel the suction cups gently using a scraper tool.
on Jan 05, 2011 | Home
Where cn I get new suctioncups for my Rival Salad shredder?
You can order a set of four (4) from lallin@juno.com; as of 1/1/15, the price was $13.50, postpaid to US addresses, $14.50 to Canada.
Apr 24, 2014 | Rival Vintage Kitcheneer Shredder Salad...
I just bought the magellan maestro, and I can't get the suction cup to stick. The surface is clean and we wet it, but it loosens rapidly.
The GPS unit comes with an adhesive disk that must be installed on the surface where you want to place the GPS unit. The suction cup will only work with this adhesive disk. Once the adhesive disk is installed, the suction cup will hold. Here's the instructions magellan web site...
  1. Clean and dry the dashboard where the adhesive disk is going to be installed using enclosed alcohol pad.
  2. Remove the protective paper cover from the bottom of the adhesive disk; place the bottom of the adhesive disk firmly on the dashboard.
  3. Apply even pressure on the top of the adhesive disk for a secure fit (Allow 24 hours to cure).
  4. Place suction cup mount on top of adhesive disk.
  5. Firmly press suction cup mount down flat against the adhesive disk, press the suction cup lever down to secure the suction cup to the adhesive disk.
Nov 03, 2008 | Magellan RoadMate™ 1212 Car GPS Receiver
The screen mounted garmin nuvi sat nav now wont stay attached to windscreen
sounds like you need a new suction cup assy, check the garmin webshop
Apr 18, 2008 | Garmin nuvi 350 GPS Receiver
Holder
wet the suction cup a little, press down firmly before flipping the switch to lock it down
Apr 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Suction not holding on window
wet the back of suction cup. it will hold alot better
Jan 14, 2008 | Garmin StreetPilot c340 GPS Receiver
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
63 people viewed this question
k24674
