How to remove evaparator from 1986 oldsmobile cutlass ciera
  • 1,250 Answers
Http://www.autozone.com/autozone/ymme/ymmeYear.jsp?_requestid=304737
go to this web site and enter you info on your car. I believe you will find the steps on how to handle this. Good Luck.
Posted on Sep 11, 2009
How do you check the timing on a 1988 oldsmobile cutlass ciera 3.8
images for 1988 oldsmobile cutlass ciera 3.8 wiring
Need diagram for 88 olds 3.8 engine`firing order - Fixya
www.fixya.com/.../t9979847-need_diagram_88_olds_3_8_engine_firin...
Aug 3, 2011 - need diagram for 88 olds 3.8 engine`firing order - Oldsmobile 1988 Cutlass Ciera question.
Sep 24, 2015 | Oldsmobile Cars & Trucks
Where is the fuel filter located?
For 1986 Oldsmobile Cutlass Ciera 2.8L 2BL OHV 6cyl the Fuel Filter is located: Under hood, center, upper engine area, mounted in fuel inlet line connected to carburetor.
Good luck (remember to rate and comment this answer).
Mar 11, 2011 | 1986 Oldsmobile Ciera
Location of starter motor on 1986 Olds Cutlass Ciera ?
Follow the positive battery wire to starter.
Feb 03, 2011 | 1986 Oldsmobile Ciera
I need a fuse box diagram for my 1986 cutlass ciera so I can know what each fuse does. Where can I can I find one?
you can go to www.eautorepair.net and for a few dollars you can down load the complete wiring diagram including fuses,relays and everything eles electral
Jun 25, 2010 | 1986 Oldsmobile Ciera
Where is the flasher fuse located for a 1986 cutlass ciera
Usually they are up under the dash on the driver's side....Not a fuse per se, but usually a relay like THIS.
GL,
Td
Apr 21, 2010 | 1986 Oldsmobile Ciera
Were is the starter located on my 1986 oldsmobile cutlass ciera?
follow the thick red cable from the battery,it goes right to the starter.
Apr 14, 2010 | 1986 Oldsmobile Cutlass Supreme
1986 oldsmobile cutlass ciera overheating. the car is leaking antifreeze, maybe a water pump, and whenever I accelerate it makes a rattling noise.
Sounds like a water pump , but would need to know where antifreeze is leaking from to help you solve this. There are several things that will make a car overheat , you just have to narrow down the problem and eliminate possibilities until you find the source of the problem
Nov 08, 2009 | 1996 Oldsmobile Cutlass Ciera
I have a 1986 Olds Cutlass Ciera with a 2.5l 4
Remove the belt from any pulley. Go from pulley to pulley and make sure they are all free wheeling obviously you won't be able to turn the crank pulley. Spin your alternator pulley and listen to it. It should be silent and smoothe. If you hear any bearing noise from the tensioner, the alternator, the AC comppresor, I would do this soon, you've spent on belts what an alternator would cost.Also check the idler pulley if this is a serpentine type belt.
Aug 21, 2009 | 1986 Oldsmobile Ciera
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
