Question about Craftsman Garden
Having trouble replacing a 42 craftsman riding mower belt...help Ithe old one broke off but the new one it on too tight...the replacement one is the right lenght help please
    Problem Solver:
  • 5 Answers
Do you remember the routing of the belt? there should be a diagram on the deck somewhere - best thing to do is rout the belt while the deck is lowered, leaving the loop at the front to put around drive pully on bottom of engine. once that is all hooked up, there are deck adjusters on either side of the deck - that you can adjust to relieve some of the tension on the belt - turn the adjusters clockwise to tighten, counterclockwise to loosen - let me know if this helps or if u need more info - i have a 10 year old 42" deck tractor out in my barn and if need be, tomorrow i will walk u through - online how to adjust the deck
Posted on Sep 07, 2009
Testimonial: "I've bought another belt with the proper number . I have yet to install it but I will let you know how it comes out . Thanks for your help"
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
Pto on yardman 42 lnch cut belt will not go tight
A spring keeps the tension on a PTO belt. It may be broke or unhooked.
Jan 13, 2013 | Craftsman Garden
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades will not engage, belt not broke but is very old, do I need new one?
Check if the belt is loose. With the engine off, try to pull the mower deck belt around by hand. If you can pull it easily, and the blades don't turn, then replace the belt. If it's hard to pull, and you can see the blades try to turn as you pull it, then your problem probably isn't the belt, but the PTO clutch or mower engage switch.
Jun 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42" craftsman mower deck belt 144200 to tight on the deck
Manual lists the incorrect number for this model! i learned through many difficulties. Correct belt is a # 144959, 1/2 " by 95"
Aug 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE PULLEY AND STOPPED MOWER AND BROKE BELT. IS THE BELT SIZE 96 OR 97 INCH? THE BELT HAS DONE IT TWICE/STCK BETWEEN THE PULLEY AND THE THING ABOVE IT.
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower will not stop when clutch is depressed
When you replaced the belt you either got a shorter belt or you have rerouted the belt wrong. You might try and get an original; belt and replace the one on the tractor. Good Luck-David
May 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
501 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
