Question about Mitsubishi VS-50605 50" Rear Projection Television
Connecting component video YPbPr to TV with BNC port for RGBHV
I Have a first gen HDTV which has RGBHV (RGB with Horizontal and Vertical control) input that uses BNC connectors. Could I connect the component video output of say an Upconversion DVD player to the RGB input ports of my TV and just ignore the HV ports and not lose anything, assuming of course I use a RCA-BNC adaptor to connect the two?
Thanks for your help.
VT.
    Sergeant:
  • 261 Answers
No, this will not work. Picture will roll vertically. Originally they intended for HDTV to be red,green, blue, & Horizontal, Vertical sync. That changed after the first generation mitsubishi's.
In the service menu you can change the settings for the HDTV Input. Try that first by "Hitting menu button followed by 1259" or menu 1257. Let me know how that works for you, If you need a different code for service menu...contact me again and i will look it up for you. But the answer to your question is you can make it work or you can purchase a 300.00 box that will allow you to switch to that input thru..mitsubishi.tv.com
Good luck and keep me posted. GURU JAY
Posted on Feb 19, 2008
Trying to connect Laptop VGA to TV Component (RGBHV) INPUT
Computer VGA to TV AV RCA S-Video Composite Converter, Costech HD 1080P HDTV Video Cable Converter Adapter Plug and Play for HDTVS, Monitors, Display, Laptop, Desktop, PC
Go to Amazon and for $10 solve the problem
Feb 04, 2018 | Mitsubishi Televison & Video
How do i connect my dvi to vga to my misubishi ws-65313
you can't, DVI is a digital video source and VGA is an analog video source. however there is a VGA to component RGBHV cable that you can use. the Mitsubishi TV is very limited to the resolutions the VGA output can be. only 1080I, 480P or 480I. HD component video input in the menu you must change the source from Y /Pb/ Pr to RGB.
Jun 07, 2014 | Mitsubishi WS-65313 65" Rear Projection...
I have a zx4800 touchscreen gateway and i want to conect it with the tv is it possible ?
You may be able to add a second monitor. You need a USB video adapter to get an external video port. There are no external video ports on the ZX4800 all-in-ones. Here is an example USB VGA adapter: http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 . DVI and HDMI versions also exist. These aren't the greatest solution so don't use them for gaming.
These will work if the TV has a compatible port. If your TV has VGA input, you are fine with this option. If your TV has HDMI inputs, you need to check the specifications. Some TVs have HDMI ports that do not interpret the signal from a computer. If your TV only has composite or component video inputs, you will need a converter from VGA (RGB) to the TVs input. (Component is YPbPr.) One option is http://www.ramelectronics.net/product.aspx?zpid=3294 . VGA to component video cables do not work; those are meant for projectors that understand the RGB encoding.
I hope this helps.
Dec 20, 2012 | Gateway GM5664 Desktop PC
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Connect laptop to toshiba 50h8250
This requires a converter. If the laptop has a VGA port, use an VGA to component video or VGA to composite video converter. See this site for some examples: http://www.svideo.com/pctocomponent.html . Do not use a VGA to component video cable - these are meant for projectors that use RGB signals.
If the laptop has an HDMI port, you'll need a different type of converter, like this: http://www.hdtvsupply.com/hdmi-to-component-adapter.html . Then set the output to YPbPr.
I hope this helps.
(I doubt your laptop has a video controller that can output a non-RGB signal.)
Nov 14, 2010 | Toshiba 50H82 50" Rear Projection...
Sony VPH D50Q projector doesn't see signals above 480i
HI Tom,
For some reason I cannot reply to other inquiry would you please close the problem, I am glad that the configurations worked out for you.
Al
In order to configure the proyector for hd video you would need to change a couple of things in your set up.
First you would need to use hd cables, and not the rgb. You can purchase some standard high def cables at any best buy or radioshack, depending on the source device there is the standard high def out, the set of 5 cables, 3 video plus the 2 audio.
To enable the unit to support the progressive DVD signal, perform the following
procedure.
Connect the DVD player’s component output into Input A.
In the SET SETTING menu select HDTV-YPbPr for Input A.
In the INPUT SETTING menu highlight Sync and select EXT (HV).
The IDTV module disables itself automatically
Perform this procedure with nothing connected to the component input on the projector, otherwise you will get the an off/on flickering screen which prevents you from seing what you are doing when navigating the menu screens. Perform the procedure and then connect.
Let me know if you need anything else,
Al
Aug 02, 2010 | Sony VPH D50HTU Multimedia Projector
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
How to set up hd on this tv
Hi Brien,
You can hook-up your HDTV via the BNC inputs with the right equipment below.
Here is the link to a website that sells video transcoders for projectors and projection televisions. In addition, the link will take you to one particular transcoder that will work for your application.
http://www.curtpalme.com/RTC2200.shtm If you use this transcoder you will have to find a VGA to 5-BNC breakout cable to connect the output of the transcoder to your TV HDTV RGBHV inputs. The extra VGA input on this transcoder will not be used for your application. They sell another product that comes with the cable you need, but I did not see it listed separately. That product is their HDFury Basic Kit at the link below.
http://www.curtpalme.com/HDFury.shtm
Regards,
MyTvGuy
Jan 12, 2008 | Mitsubishi VS-80803 TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
207 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
