Question about Dell UltraSharp 1907FP 19" LCD Monitor
DELL 1907FP MONITOR
1907FP POWER ON/OFF BUTTON IS NOT WORKING
    Problem Solver:
  • 5 Answers
There were no screws on the back of my monitor so that was not an option for me. I figured I didn't have much to lose, so I took a very thin and small screw driver and pried the on-off button right out of its socket, which does break it. To the left, inside the hole,you can see where a tab on the button pressed against a small circular inner button. I pressed that with the screwdriver and the monitor turned right on. I replaced the button for the sake of cosmetics and will never touch it again. If I leave the monitor for any extendd period of time I will simply unplug it.
Posted on Sep 12, 2009
  • 788 Answers
In the front of the LCD their is a plastic ring.
I can't remember the name for this peice Blez ?? Anyway, back out the screws on the rear of the monitor and useing a plastic knife on the bottom pry open. Their is a thin printer circuit board behind the cover.
Posted on Sep 11, 2009
4 Suggested Answers
SOURCE: Removing front bezel of Dell 1907FP monitor to repair stuck power button
it is not the same. they are assembled differently. there are no screws on the back corners of the monitor to take it apart. it all seems to be one piece, and more difficult to take apart.
Posted on Jun 24, 2008
SOURCE: Power button stuck on Dell 1907FP
OK, thanks to hihai above, I was able (finally) to get into my monitor. A word of caution, though. Use a wide, thin knife and insert it between the grey plastic and the black plastic at the top or bottom of the monitor. (its easier at the top or bottom as you can distinctly see the deliniation between the grey and black - on the sides it's all black and the fit of this bezel around the monitor is so tight it's really hard to get in to the crack to pry the thing off). At any rate, once you get your thin knife (I too used a butter knife) into that crack, gently slide it to one end or the other. There are tabs near each end and a couple in the middle - you'll feel a bit of resistance near each tab as you slide the knife. Position the knife close to one of the end tabs. Rotate the knife handle outwards away from the monitor effectively prying the bezel upwards away from the face of the monitor. As you pop each tab, work towards the opposite end of the same side of the monitor. Once you have both ends dislodged, inserting the knife to pry up the all black sides will be easier. Unfortunately once you have the top (or bottom) and both sides loose the remaining top (or bottom depending on which one you started with) becomes a bit tighter to get the knife into.
Here's my word of caution. Be very gentle. While I was trying to find the way to get the bezel to come off I attempted to slide it in between the monitor face and the bezel itself and unfortunately cracked the glass face inside the monitor rendering it useless.
As for the power button, the button had worn down so much from use there simply was no travel left to push the contact on the switch board in the bezel. I tried a dab of hot glue on the inside of the power button to give it some more contact to the switch on the circuit board but didn't have enough. I was able to push the switch on the board with the circuit board removed from the bezel (with a tiny screwdriver not my fingers) and the monitor powered up fine. It was then I discovered the broken screen. Damn.
Posted on Aug 31, 2008
  • 81 Answers
SOURCE: Power Button Broken?
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
Posted on May 20, 2009
On/off button stays in. won't work
Cheaply made part that is non-replaceable. One solution is to drill a small hole just to the left of the power button big enough to insert a toothpick through. Power can be turned on and off with the toothpick. Can use a paperclip but it will scratch up the bezel on the outside and the circuit board on the inside.
Jun 12, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
I have a Dell monitor model 1704FPT,, seems like the power button has come loose inside.. Can I get inside to repair it .. Thank you
You can turn counter-clockwise the screwz at the back cover of your monitor to open it & check if the power button is loose or defective, even notice if some internal part/s are cold soldered / defective. However, if it's still under Warranty, I recommend to bring the unit to an authorized service center for a Free service check-up & replacement part/s. best regards
May 22, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
May 20, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
Dell 1907fpf will not power on.
Please search for "Power button stuck on Dell 1907FP" and see the advise from other members. I solved my by following their instructions.
Feb 15, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Thanks,
Chris
http://BoiseLCD.webs.com
Jan 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fp USB port not working
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Jun 09, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fp picture "shifts up"
It is most likely the cable, it is where most faults of this ilk lie in LCD monitors. :-)
Mar 27, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
662 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
