Question about Canon Pixma iP6210D InkJet Photo Printer
Cartridges do not Move & the Printer Shut Downs Automatically
I've a Canon Pixma iP 6210D printer. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I used it occasionally. Some days ago when I tried to use it then after turning the power on I could not found any movement of the ink cartridges. Just able to perceive a sound but it’s staying on the right position.
Within a few seconds the power also turning off automatically (just after showing “Canon: in its LCD) without completing the booting.
Please help.
Thanks
The cartridges do not move to the
  • 4 Answers
Tell if the cartridge iss moving a litle or is totaly bloched
Posted on Sep 06, 2009
Ink Cartridges too far over to replace
Unfortunately you haven't mentioned if your printer is switched on at the time, but if you are changing cartridges your printer should be plugged in & switched on when you open the cover to replace the cartridges.
The printer cartridge carriage should then automatically slide to the center of the printer where the cartridges can easily be removed and replaced.
Thank you for visiting Fixya.
Best wishes,
Graemevm
Mar 25, 2011 | Canon PIXMA MX310 All-In-One Printer
I have Canon Pixma IP6220D When I turn on the printer the power led is flashing 4 times and turn off automatically. Can someone help me to resolve this problem?
Hi
I had same problem: when the printer needs more current to move the cartridges, the power supply switches off. To solve it, I replaced a broken diode in the power supply unit, and now the printer works fine.
Nov 21, 2010 | Canon PIXMA iP6220D InkJet Photo Printer
Coming up with check ink U161 cannon pixma ip 6210D
Open the lid, remove the ink, clean with fine tissue paper both inside and the ink connecting rimb. replace properly as instructed. You may need to put off AC supply and on again. Also be sure you are replacing with the right cagride number.
Jul 25, 2010 | Canon Pixma iP6210D InkJet Photo Printer
I am getting a message on screen saying that the waste ink collector is full. It is telling me to contact service. What can I do myself? Canon Pixma iP 6210D
Hello sir; You have to clean upthe ink collector by yourself, the procedure as follow; turn on the power open the top part ( same as when repace the cartridge) let cartridge carrrier move to the center then UN-PLUG the power, now you may move the carriage freely, move it to all the wayto the opposite direction from the ink collector, now you can clean the cell, after you clean up, turn the power switch off before you plug in the power cord.
Nov 22, 2009 | Canon Pixma iP6210D InkJet Photo Printer
Although using canon inkjet cartridges 40 & 50
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-4
Aug 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
Canon Pixma iP 6210D: cannot replace cartridges
the drive control is malfunctioning and costs more to repair than replace
Jul 07, 2009 | Canon Pixma iP6210D InkJet Photo Printer
Canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Feb 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I need to download the start up disk or whatever I need to setup my printer again. I had it disconnected but now that it's reconnected I cannot find the start up disk that it's asking for. It's a PIXMA iP...
Hi sarafian -
Here is a website address that has the drivers for your specific Canon printer.
http://driverscollection.com/?H=PIXMA%20iP6210D&By=Canon
You can go ahead and click on the link that says Download Canon PIXMA iP6210D Easy-PhotoPrint v.3.61 driver. Just a heads up that I would not connect the printer to the computer until it asks you to during the driver installation.
Hope that helps,
Take care,
Michael
Nov 15, 2008 | Canon Office Equipment & Supplies
Change ink cartridges
hi,
532
Oct 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma iP6210D InkJet Photo Printer Logo
174 people viewed this question
old marine
old marine
