Question about Maytag Neptune FAV6800AW Top Load Washer
Water will not shut off - Maytag Neptune FAV6800AW Top Load Washer
  • dh1200s
    dh1200s May 11, 2010
    Is your washer a FAV6800AW or FAV9800AW? If it is I will post troubleshooting steps. The pressure switch in this machine is mounted on the drain pump and signals the control board via pressure switch contacts. Again if a replacement is required the serial number is needed. It?s on the right back side of the console. Does the water turn off if you unplug the machine during the water fill cycle?
  • 4,070 Answers
If the washer fills and don't start the wash cycle...
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It need replacing.
Posted on Sep 06, 2009
Tip
Eaton Home Heartbeat Water ShutOff Controller...
The Water Shut-Off Controller can be linked to HOMEheartbeat water sensors (HHBWATERSNSR) to automatically shut off your house's main water linein the event of a water leak. Simply place Water Sensors in high-riskareas for water damage. Then install your Water Shut-Off Controller onyour main water line and setup the unit to turn off if a Water Sensorbecomes wet. Then, when the icemaker malfunctions or the toiletoverflows your Water Sensor will become wet and your main water linewill close, minimizing the costly water damage.
NOTICE! This product requires installation of, and will only work with a HOMEheartbeat Ball Valve. Ball Valve installation may require professional plumbing assistance.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the User Manual at FixYa
on Jan 03, 2009 | Eaton Home Heartbeat Water Shut-Off...
WATER HEATER WAS LEAKING FROM BOTTOM OF TANK, I SHUT OFF WATER VALVE, AND SHUT OFF PILOT IS IT NECESSARY TO SHUT OFF GAS LINE GOING TO HOT WATER HEATER HAVING A NEW ONE INSTALLED TOMORROW
Yes, you have to shut off the gas going to the water heater. There should be an inline shutoff around it. Otherwise your going to be leaking a lot of gas which is very dangerous.
Apr 03, 2016 | Water Water Heaters
Where are the shut off valve to cut the water off
Should be on top of the water heater cold water supply.
Feb 23, 2015 | Water Water Heaters
How to change the water filer on a rf4267hars 25.5 ft
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Apr 02, 2013 | Samsung RF4267HARS 25.5 Cu. Ft. French...
Water dispenser wont shut-off
Check the solenoid valve is not stuck open. It lets water in, pushing cold water out, and if stuck will not shut off.. It may even have a broken spring, but that is quite unusual
Apr 21, 2012 | Refrigerators
Where is water shut off valve on Rheem Electric Water Heater?
The shut-off is not on the water heater.
The shut-off is usually located on cold water pipe that enters water heater.
See image of shut-off:
http://waterheatertimer.org/images/Low-water-pressure-2-800.jpg
If shut-off is not located on cold pipe at water heater, then turn off water to house at water meter.
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Sep 25, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of...
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
HOTPOINT WD62 FILLS WITH WATER WHEN NOT BEING USED
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
-Vince
Oct 03, 2008 | Hotpoint Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
