Tapes go in but get stuck, VCR won't play
I have a VG2030 (GE) VHS model...the only thing that seems to work right now is the power button..the tapes go in but get stuck after pressing the eject button...the VCR won't play the movies...the timer button blinks also...
  • Televison & ... Master
  • 5,056 Answers
It sounds like a mode switch failure to me. You will need to replace it, you will also need to set up the machine properly when the new one is fitted, as the timming will most likely be off, so you may need the service manual or a guide to set it right.
Posted on Sep 06, 2009
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
DRC 8335 Playing Back VCR Recordings in a Fast Forward State
I bought mine yesterday and am having the same issues. No solution listed in the user manual to fix this and I have a rather extensive VHS tape library that I was hoping to move to DVD using this unit. Unable to watch any VHS tapes taped on my Panasonic VCR and it seems as if the tape is slipping. Tracking buttons don't fix anything. I found a blank spot at the end of the tape and taped something and it comes out fine. Could this have something to do with it being a 6 head VCR? Tapes are in SLP mode.
Jan 08, 2008 | RCA DRC8335
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
May 27, 2007 | Daewoo DV-T8DN VHS VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
