Question about Refrigerators
Every day at some point my fridge spits out a puddle of water on the floor underneath the right to front side looking at the fridge. It is a frigidaire 20.6 cu. ft. top freeze. I have made sure it is not over full and has proper ventilation. What is the problem. We did move resently.
  • Mike Smith
    Mike Smith May 11, 2010
    If you have an icemaker , check that the water line connection is tight .
  • 89 Answers
The drain for the defrost is stopped up you will have to remove the back panel inside the freezer remove the ice that is built up find the drain hole and clean it out sometimes you can remove the drain hose from the back of the ref and clean it out some models dont have a hose on the outside thes models you will have to take apart like i said
Posted on Sep 07, 2009
Water leak in floor
orIs the water coming from above the floor(front or side windows)(is the puddle big) or from underneath the floor(slowly spreads)? I think you have a lot of water coming in from a leaky window gasket, most probably in the front window.
Mar 12, 2013 | 2004 Lincoln LS
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Leaking water on the front corner of the freezer side. We have turned off the water to the icemaker and have turned off the icemaker. Still leaking, not fast, but each day I clean up a puddle.
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket. Look in your freezer floor for ice build up. If you don't see anything like that or if you think the water is coming from underneath the fridge, then it is your condensate pan underneath. They crack sometimes.
Sep 06, 2009 | Frigidaire Refrigerators
No cooling no freezing puddle on floor
Your defrost drain line is frozen over. Turn off the fridge and defrost the drain in the lower rear portion of the freezer.
Apr 23, 2009 | Kenmore 53642 / 53644 Side by Side...
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
