Hi, Just bought new hdmi dvd. Tried connecting to tv but getting blue screen with sign reading "no signal". Please help.
  • 132 Answers
You need to push your input button on the remote control and scrool down to HdMI 1 or 2 depending on what port you have it hooked to the port on the TV will say 1 or 2 on it this will give you your picture .
Posted on Sep 06, 2009
How to repair HTMI port "no signal" on screen
Just pull out the socket to the port, and fix an other in that place. It will come out easily as you pull out, and can be fixed a new one for just one hard push.
Sep 26, 2016 | RCA Televison & Video
Hello, the DVD play fine but tv mode, continually says no signal and screen is blue. Please help
You either have the DVD player plugged into the wrong input on the TV or the TV not set to that input. If using HDMI change the HDMI cord to another HDMI port on the the TV. In an Extreme case you have a bad connecting cord (either HDMI or other type.)
Oct 27, 2014 | Akai LCT3201AD 32 in. LCD Television
Restart and blue error screen
Get a new HDMI Cable as that HDMI may have an internal short or disconnection
Aug 24, 2014 | Computers & Internet
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Black Screen - No Signal when connect Bluray to TV with HDMI
I just had the same issue and I believe it was because the sound bar was turned off. The solution was turning on all of my connected equipment such as my sound bar, cable box, tv, blu-ray player, and internet router. It stopped "disconnecting" after only 30 secs of being turned on. I think it was because my husband connected it to all those things in some way so the settings are set to work with those pieces of equipment. With one powered off, in my case the sound bar, the signal can't run full circle and reads as if cut off. Please excuse my nontechnical terminology.
Dec 28, 2011 | Philips BDP3000 Blu-Ray Player
I am connecting a RCA DVD player (DRC277B) to my TV and have problems when using the HDMI cable. When I connect the unit using the AV Cable, things work OK. I then turned off everything and hooked...
Hi
Thanks for using FixYa. Two things that will cause the “No Signal” message to come up are - no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn it off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the not available message. I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts
Try using Component cables if this doesn’t make a difference. After using components cables the issue will be resolved. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 15, 2010 | RCA Televison & Video
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
My Samsung LN40A530 only produces a blank blue screen whenever I try to use an HDMI input source. Audio seem to come through fine but not the video. Other, non-HDMI video inputs work fine. I've tried...
We are having the same problem. We have 2 DVD players with up-converter to 1080i and 1080p. Both DVD work fine (one Sony and one Samsung) with our Samsung LN-T4053H upstairs, never intermittent.
LN40A530 downstairs is having "Searching for Signal" problem. Took it back to Sears got a new one, problem followed. Something is wrong with this LN40A530. Perhaps firmware update is needed.
Jun 11, 2008 | Televison & Video
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
