Question about Audio Pro 15PLB76 15 Inch 800 Watt Woofer Car Speaker
Peugeot 106 I have purchased a set of 6x9 speakers, and I intend to fit these to my parcel shelf. I was wondering what is the best method to run the cable from the head unit, to the rear of the car? If possible, without lifting the carpet?
    Sergeant:
    Champion:
  • 231 Answers
You could use existing speaker wire from original speakers.and or just run new wire thru plastic kick panels , thru plastic base boards theh thru plastic rear kick panel ,thru rear seat ...
Posted on Dec 08, 2007
How do you remove rear speaker covers in a 96 geo
are they fitted in the rear doors or the parcel shelf ,if there aree no visable screws to un do if door fitted then will have to remove the door panel , if on parcel shelf same thing if no screws visable then remove from underneath , hope this is of some help
Sep 29, 2014 | 1996 Geo Prizm
What size speakers are in the doors on a 1997 jeep grand cherokee laredo
  • The factory speakers are 6x9 BUT the magnet on the factory speakers are much smaller than on aftermarket, higher quality 6X9 speaker making it almost certain the window will not roll down after installing an aftermarket 6X9.
  • Most go with a 6X5 because they are a bit smaller and there is a wider variety of them. Where ever you go to purchase that speaker. make sure the measurements are taking real well if going with another 6x9. There is always the option of the factory 6x9 but a nice aftermarket will fit in there so long as you mind the size.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 07, 2011 | 1997 Jeep Grand Cherokee
Regards, Tony
VT Commodore 6x9 Speaker install
Hello taz_is_1,
Sure, it's OK as long as the new 6X9's are the same impedance as the door speakers.
Unless there are already wires and cutouts for rear shelf speakers, the installation will be pretty involved. And while I'm not sure of the Holden product, it's sister versions, Chevy Lumina and Omega, does not have such cutouts or wiring.
Wires going into the door interior for window controls, locks, and speakers will all be in a bundle and go from the vehicle frame into the door through a flexible rubber connector with grommets on both sides. You'll need to run your wires from the disconnected door speakers back through the same grommets to avoid pinching and damaging them. After you get them back into the vehicle interior, you can run them under the trim or carpet to the trunk area under the rear shelf. If you have never done such work before, I recommend you get someone who has to help you. You'll need to make an appropriately sized cutout to mount the 6X9's. And depending on the material, you may need some kind of reinforcement and/or spacers. Also, look out for anything underneath the trunk lid that may come into contact with the speakers. There's usually 2 metal rods than span the width of the trunk and run almost directly under the shelf. They will have to clear the speakers in order for the trunk to open and close properly.
It's more work than a simple speaker exchange with a good pair of aftermarket speakers. And the benefit is minimal. A really good set of 5 1/4, 6 1/2, or 6 3/4 Alpines, Bostons, or Infinitys will sound better than a mediocre set of 6X9's any day and you don't have to cut everything up to install them in most door openings.
Hope this helps.
Sep 07, 2009 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
Vt Holden Commodore stereo wiring diagram
head down to your local auto store and you will be able to pick up a wiring harness adaptor. you wire your stereo to this adaptor then you simply plug it into the wiring loom. no damage to the loom so if you ever need to reinstall the standard stereo its just an unplug and plug back in. its extremely simple and colour coded so there are no mistakes.
May 02, 2009 | GMC Jimmy Cars & Trucks
I am about to put my 6x9 speakers in my car. i would like a little advice if possible. it will not be a tricky job as all the connections have been done (by a car garage). all i need to do is put the...
Typically the best way would be to remove the interior trim piece from the shelf. Then have a friend hold the MDF board up from inside the trunk. Then run either screws or bolts/nuts through from the interior all the way through the MDF. Replace interior trim piece and it should be held in tight.
Another less intrusive way would be to use a strong adhesive, such as "Liquid Nails" to secure the MDF to the bottom of the shelf. You'd need to figure a way to hold the MDF to the bottom of the shelf for quite awhile (8-24 hours) to make sure their is good adhesion.
Jan 31, 2009 | Car Audio & Video
6 by 9s
you will have to make a 6x9 templet and them you will have to cut it out.
Jun 20, 2008 | JC Whitney - Audiosonic 3-way Custom-fit...
6x9s in a clio
forget it...
buy some speaker cable & run them from the head unit to the boot.
from the back of the stereo connect as follows:
Rear Left
green + to Big Spade on speaker
green/black - to Small Spade on speaker
Rear Right
purple + to Big Spade on speaker
purple/black - to Small Spade on speaker
Dec 04, 2007 | JBL LC-S960 Car Speaker
Car Audio & Video Logo
310 people viewed this question
Top Audio Pro Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you an Audio Pro Car Audio and Video Expert? Answer questions, earn points and help others
