Question about Refrigerators
I simply cannot get the grille off a side by side whirlpool refrigerator. I opened both doors but it won't come off and I'm afraid I will break it. What is wrong?
  • evanslaura Sep 06, 2009
    There are no tabs on top of this refrigerator.
    Problem Solver:
  • 11 Answers
There are two tabs on the top of the refrigerator. To see them, you'll need to get almost over top of it and pull firmly. Once you see the tabs, push down with your thumbs on the spots with the tabs, and it should rock down and off. There are small hook like clips on the bottom that hold it together. Don't worry about being too rough with it when you put it back on either. You'll need to put the bottom hook thingies in the holes, and then rock the grille up flat. Bang it with the heel of your hand where the clips are, and there ya go. :)
Posted on Sep 06, 2009
How to remove bottom vent on refrigerator
There are only two "clips" equidistantly spaced along the length and near the top of the vent grill. Important: Open both doors on side by side as the top of the vent grill has a lip that extends from the top to under the two doors.. Pick a side and lightly pull straight out, repeating procedure for opposite side. Remember to open both doors when re-attaching.
Aug 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cannot attach toe plate
Hello - To remove the toe grille you will need to have the doors of the refrigerator open, the grille simply snaps into place. Remove the right side first and then the left, as the water line is on that side. When replacing follow the steps in reverse.
Nov 04, 2012 | Frigidaire FRT21H8 Top Freezer...
Where the water filter whirlpool gold model no GS6SHEXMQ00 located? the last home owner lost the manual.
The base grille water filter cartridge is located below the freezer
compartment door. Depending on your model, you may have a
filter that is installed behind the base grille or a filter that
is installed through the base grille
This should be the right manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202188772.pdf
Mar 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do i remove water filter under the side by side refrigerator
filter should be removede by turning filter counter clockwise,as if "unscrewing",so to speak.no need to shut off water or anything,just unscrew-tip:might be easier to remove by removing ref. grill. ref. grill removes easier by doing this w/ both doors open
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
Doors are hard to open on my new Whirlpool Conquest sided-by-side
2 things come to mind:
1) Check to see if the unit is level
or
2) if it is simply a suction issue when opening, try wiping the big gasket and the contact surface with some furniture polish
Aug 10, 2009 | Whirlpool GS6NBEXR Side by Side...
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Whirlpool Gold. Front grill won't come off.
when you remove this grill it feels as if it will break before coming off. the trick for removing it is to grab in the center near the bottom and then pull up and out. it will flex alot and feel as if it might break put it will pull loose from the clips on either end. open the doors when removing it to give you plenty of room.
to reinstall line the 2 "c" clips on eihter end with the with the reciever clips on the unit then push into the clips.
the grill will not break if done this way. message me back if you have nay further questions thanks Peyton
Feb 23, 2009 | Whirlpool GS6NBEXR Side by Side...
Problems with Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing...? How do I remove the front panel in order to get access to the icemaker parts?
Use a screw driver to pry up at the two notches at the bottom of the panel. I thought that might work, but had been afraid if I did I would break the panel.
Dec 03, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refridgerator
side by side ice and water in the door?open both doors and remove the bottom grill.on the left is a drain pan.is it full or mostly full?the condensor fan motors are known to give out gradually.they may run for a day and not the next two.
Jan 13, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
