Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Crafstman 41A435-7A I have a crafstman door opener k1027, part Nº 41A4315-7A,1/2 HP motor outdoor, that open a slide door; the problem is that the electronic board is broken, and I want to know if I can find a similar one o what door opener do you recomend me. Thank you
    President:
  • 3,197 Answers
If the board you say is broken is the one you got the part #41A4315-7A, that is the part number you need. You can get it at Sears or any good door service company.
Posted on Sep 07, 2009
HP cp1215 toner tray stuck
Call hp and sit on the phone until they answer. They will talk you through it.
Oct 08, 2012 | HP Color LaserJet CP1215 printer...
Toner cartridge tray is stuck and will not slide out. Any help would be great.
open front door, when machine starts to run and turn motors about 1 second, open front door. Toner tray should slide out now.
Aug 28, 2012 | HP Color LaserJet CP1215 printer...
The power side passenger door for a 2001 Chevy Venture van works every so often. The door doesn't move when the button is pressed on the panel in the headliner. The key remote doesn't work most of the time...
The proper way would be to look at a wiring diagram an test the electrical circuit's with a DVOM - digital volt ohm meter . Do you know how to test automotive electrical circuit's ?
Electric Testing Techniques You Need to Know
The Trainer 32 How To Read An Automotive Block Wiring Diagram
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter the vehicle info. year , make model and engine size . Under system click on body & accessories ,then under subsystem click on power sliding door . Click the search button then the blue link. Looking at the diagram you will see a control module is used .
Also reading factory service info. on how it works would be a good idea.
Rear Side Door Actuator Control Module
The rear side door actuator control module is capable of on-board diagnostic functions described in On-Board Diagnostic Features . The rear side door actuator control module monitors the door position at all times including during manual operation. After activating the on-board diagnostic modes, loosing battery voltage, or ground to the rear side door actuator control module the Power Sliding Door (PSD) Re-Initialization procedure must be performed in order for the rear side door actuator control module to correctly determine the door position.
Power Sliding Door System Description
The power sliding door system(s) can operate correctly only if the power sliding door is in proper mechanical condition. Any mechanical problems will affect the power sliding door operation and must be repaired before attempting to diagnose the power sliding door system. Manually open and close the power sliding door to determine if the door moves smoothly and without excessive resistance or binding. The power sliding door must also latch and unlatch without the use of excessive force. At any time during power sliding door open or close operation, excessive resistance to the door movement will cause the power sliding door to stop and reverse the direction of travel.
The power sliding door will operate only when the power sliding door on/off switch in the overhead console is in the on position. At anytime during power sliding door operation the on/off switch may be turned to the off position and the system will quit any function in process. The power sliding door will not open unless the transmission shift lever is in the park position and the door is unlocked. When the sliding door security lock is in the locked position the power sliding door will not open from the inside. The power sliding door close function will operate when the vehicle is in gear. The power sliding door module uses the VSS signal to determine if the vehicle is moving during a power sliding door close function. The momentum of the vehicle moving forward adds resistance to the door closing operation. When the rear side door actuator control module determines the vehicle is moving forward while closing the door, current flow through the actuator motor is increased instead of being reversed. The VSS signal circuit is supplied battery positive voltage through a resistor then monitored within the rear side door actuator control module. The VSS signal circuit is then pulsed to ground, or pulled low by the powertrain control module in relation to vehicle speed. The sliding door alarm will sound repeated short tones whenever the power sliding door system is turned on and the door is open while the transmission is out of park.
When the power sliding door system is on and manual operation of the power sliding door is detected the rear side door actuator control module activates the power assist feature. When the power assist is activated the power sliding door will continue to open or close without any further manual effort.
The power sliding doors may be operated using the Remote Keyless Entry System. The keyless entry transmitter will have one OPEN/CLOSE button with a van symbol on it for each power sliding door. The power sliding door ON/OFF switches in the overhead console must be in the ON position in order to operate the power sliding doors using the keyless entry transmitter. When a right hand power sliding door OPEN/CLOSE function is activated using a keyless entry transmitter the exterior lights will flash once indicating the RKE module has received the OPEN/CLOSE command. When activating a left hand power sliding door OPEN/CLOSE function with the keyless entry transmitter the exterior lights will not flash.
The left and right power sliding door systems operate as independent systems. The on-board diagnostic modes are entered and operate the same in both systems.
The power sliding door systems are capable of the following on-board diagnostic functions:
• Diagnostic Mode 1: An audible signal indicates the diagnostic trouble codes stored by the rear side door actuator control module.
• Diagnostic Mode 2: An audible signal indicates when inputs to the rear side door actuator control module are active.
• Diagnostic Mode 3: Performs an output test of the sliding door unlatch actuator.
Entering On-Board Diagnostics
The on-board diagnostic modes can only be entered in a sequential order from modes 1-3.
• Enter the right power sliding door system on-board diagnostics using the right B-pillar open/close switch and the right on/off switch in the overhead console.
• Enter the left power sliding door system on-board diagnostics using the left B-pillar open/close switch and the left on/off switch in the overhead console.
1. Both power sliding doors must be closed and in the latched position.
2. Place the ignition switch in the OFF position.
3. Place the on/off switch in the overhead console to the OFF position.
4. Press and hold the B-pillar power sliding door open/close switch.
5. While holding the open/close switch, operate the on/off switch through 10 ON and OFF cycles within 10 seconds stopping in the on position.
6. The sliding door alarm will sound 1 long tone indicating diagnostic mode 1 is active.
Diagnostic Mode 1
Upon activating diagnostic mode 1, DTCs will begin to be signaled by the sliding door alarm. The DTCs are 2 digit codes and the codes are represented by the number of buzzes for each digit of the code number. For example a DTC 12 is represented with the following sequence: buzz, pause, buzz, buzz, long pause. Each DTC will be signaled 3 times before proceeding to the next DTC. Refer to Diagnostic Trouble Code (DTC) List . The DTCs will continue to be repeated in this manner until the on-board diagnostics are exited or mode 2 is entered. When exiting the on-board diagnostics all stored DTCs will be erased from the rear side door actuator control module memory.
Oct 13, 2017 | 2001 Chevrolet Venture
How do I program a remote garage door opener for a Crafstman 139.53615SR?
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Hold down the button on the remote while you press and release the smart/learn button. If everything is working and it is the right remote for the opener it will be programmed.
Aug 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp opener won't open using the outdoor keypad. It will close when using the outdoor keypad but not open. Wall unit closes and opens it. changed battery in keypad, no difference
If your hand remotes work okay then the keypad has lost signal strength and needs to be replaced. If your hand remotes act the same way then your logic board is bad.
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My crafstman garage door opener goes down and then
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear and is probably stripped.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remove the cover and check the drive gear. It could be stripped.
Mar 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
My i/2 hp crafstman chain drive opener stops about a foot from the floor i got it up and noticed the chain was sagging about a foot below the bar how dow I tighten the chain
The adjustment for the chain is on the trolley. That is the part the chain and the door are connected to. Your chain is sagging entirely too much. Have you done any other work to this opener?
Oct 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
668 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
