Question about RCA Televison & Video
I have a 1999 Model F27665 27in with color crazy screen. I am a 65 years old tech. and I have manageto trace the issue that seem to be the screen startup degauzing--has no effect. At RT201, there was just 2 wires sticking out which mean I might have vacumed the burnt part and I don't remember what is an'RT' of course 120v is routed to a coil around the back of the tube for 2 second or so every time I turn it on. Now nothing of the kind. It's my huntch that this is where the trouble lies. What is an RT and what would be its value. Where do I get that quick. Where can I get a teck manuel for this model of chassis CTC 203 AX GUYL
  • 93 Answers
Your huntch is right. "RT" is the source for degaussing and power Normally it a positive reaction resistor . jumper 4 ohm 5 watt to check everything else. Svc info can be found at Vance Baldwin.com
Posted on Sep 07, 2009
Where is the cycling clutch orifice tube (CCOT) located in a 1999 GMC Yukon with rear air?
CYCLING SWITCH IN THAT YEAR MODEL IS USUALLY LOCATED IN THE COMPRESSOR ITSELF,USALLY HAS A 1 wire button type wire connection on top of compressor. it's held in by a snap ring
Aug 26, 2012 | 1999 GMC Yukon
6 inch Shadow on tv screen of a Optomatv model RD65
OK , the tech was yanking your leg . second its the light tunnel has collasped , if parts are available maybe , other wise L/E ( light engine).
Jul 08, 2010 | Optoma RD65 65" Rear Projection HDTV
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
String Art 2
It is failure of convergence out ICs and subject part needs to be replaced, TV has 2 ICs and both will be replaced.
If you are tech person or know TV repair, let me know to provide you more info or call local TV tech to fix it.
Feb 14, 2009 | Sony KP-65WS500 65" Rear Projection...
Mitsubishi WS-65905 DTV is green
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
Jan 04, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Sound but no picture
loss of picture with sound ..loss of picture could one of many problems.. these units have serval specal fuses that a tech would need to check. loss of high voltage is a possibility. i would think this would be worth getting a tech to check out, the fact you still have sound may be a positive,
Jan 03, 2008 | Televison & Video
Mitsubishi Daimond Series 65" Model#WS-65909
Most common repair is one or two open fuses in power supply
and bad convergence Ic's = expensive repair.........Also, have
the tech check for coolant leakage from CRT's...........T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
