Condensor froze up solid also lines leading to compressor
    Problem Solver:
  • 11 Answers
Three things, low on freon. Or low air flow. Or a crimp or something stuck in your high pressure (SMALL) line.
If its # 2 or # 3 you will notice it starting to freeze just after the expansion device. Also if you have air or other NON CONDENSABLES in the system it will freeze this way.
It may take some time to go through all the test to figure this out or you may hit it the first time. Hope This Helps;
JSTACH
Posted on Sep 07, 2009
Where is the orifice tube on my 2004 gmc envoy xl air conditioner system
Not sure specifically on that model but if you follow the line from the compressor to the condensor then out of the condensor to the evaporator it will be between the condensor and evaporator usually the tube is wraped in plastic but it could be in the heater box itself also if you have rear ac the rear unit uses a thermal expansion valve on the rear evaporator not an orifice tube. What is your concern thats leading you to find the orifice tube if your dont mind me asking
Jul 03, 2015 | GMC Cars & Trucks
What is wrong with the Kenmore Elite refrigerators they have now? I bought one and it is very noisey. I hear the compressor running from rooms away and it's not a rattling just the noise of it running
If you are wanting to check and see if the compressor is operating and actually working, find the small refrigerant line coming off the compressor and follow it several inches and check its temperature. The normal temperature is over a 100 degrees and should feel very hot. Be careful the normal range is over 140 degrees on most model and may cause burns. If it is hot to the touch, that means the compressor is working. If it is not hot it means you have some problems with the compressor and probably need a new one.
If it is hot, the most common problem with a real hot compressor is a dirty condenser. If your models compressor hot line dissapears into the casing (walls of the refrigerator) then you cannot clean the condensor, but if it goes into a finned condensor with a fan, you need to check if it is dirty and just needs cleaning. This is a very common problem and periodic cleaning needs to be performed. Your refrigerator loses heat removed from the interior by rejecting the heat to the air passing over the condensor. If it can not breath due to dirt buildup, the refrigerator will over heat and lead to prematur breakdown. If the systems has operated long enough at a high temperature, the refrigeration oil in the refrigerant system can decompose and form sludge and block the capillary tubing. Once sludge start forming it is very difficult to flush the sludge out and a compressor change out typically can not fix the system because remaining sludge. In this case it is cheaper to buy a new refrigerator and remember to clean the condenser every year at least, more ofter if you have cats and dogs. They have a tendency to shed and the hair gets into the condenser. I had a customer once that used the air flow to the condenser as a vacuum cleaner because the dirt dissapeared near the air suction, until the condensor clogged up and the refrigerator stopped cooling, go figure.
Hope this helps
Aug 01, 2014 | Kenmore Refrigerators
Water Filter Frozen
Air blowing directly on things like a water bottle has frozen it solid ( in the REFRIGERATOR SIDE! -- Block airflow BUT... I think the problem is YOU NEED TO CLEAN ( blow out with air!...the ONLY WAY) YOUR CONDENSOR COILS ( in the back, outside...behind the cardboard cover nowadays) Your fan has to run too long ( because refrigeration is the "removal of heat"...this is what those coils do but they are insulated with dust!)...too long blowing to achieve the same temp result = Frozen Stuff
Sep 24, 2017 | Frigidaire Refrigerators
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
WHERE IS THE HIGH PRESURE PORT IN S 70 T 5 1999 MODEL
AC DISCHARGE SIDE HIGH PRESSURE SIDE IS LEADING FROM AC COMPRESSOR REFRIGERANT LINE TO CONDENSOR THE HIGH PRESSURE SIDE PORT ON REFRIGERANT LINE ON THE CONDENSOR.
Jul 21, 2011 | 1998 Volvo S70
The unit will not cool below 78 degrees. How do I check the freon level?
Without refrigeration gauges, you can't check your freon level. You have to check the pressure of the freon, not the level. If you are careful and have a basic knowledge of electricity and moving parts, you can get an idea if you are out of freon. If you remove the lower slotted cover from the refrigerator you will see the condensor coils. This is a radiator that has aluminum fins on the front and will have a fan running behind it. If the compressor is running this condenser coil should be hot to the touch at the top part of the aluminum fins. If the fins are covered with dust and dirt it can cause your cooler to malfunction. Also if the fan is not running the compressor will overheat and quit. If you pull the cooler away from the wall, you can see the compressor in the bottom of the cooler. There are two copper lines leading to the compressor. The small line goes to the condensor coils (the radiator) and should be hot enough to burn your finger if you have enough freon. Also the larger of the two copper lines brings the freon back to the compressor from inside the cooler. It should be cold to the touch if you have proper freon pressure. If both of those two lines feel about the same temperature, either the compressor is not running or you have no freon. BE CAREFUL! There are electrical lines and moving fan blades near the compressor, and some of the tubing gets really hot.
Sep 22, 2010 | Beverage-Air MT17 Refrigerator Commercial
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
Air conditioner constantly running, not cooling house
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
