Question about Motorola Mobility W385 Cellular Phone
My ringer doesn't work? I have a w385 motorolla phone, and the the keys sound, but no ring tones? How can I fix this?
Blu Advance 5.0 ringer sounds won't work.
Hi if u have silent mode turned on u won't hear a sample ring tone check where u adjust volumes there should b a silent mode on or off..Cheers..
Dec 20, 2016 | Blu Cell Phones
Need ringer on uniden ex14246
With the phone in standby mode (not talking, not doing something in the menu, etc), press vol-up or vol-down. The phone will sound the different ring tones at different volumes. To turn the ringer off,
select "Ringer Off". When the phone sounds the ring tone and volume you wish to use, press the end key.
Oct 14, 2011 | Uniden 2.4 GHz Cordless Phone System
My phone has "Ringer Off" how do I fix this??/
My cordless is a VTech ... so not quite the same, but you need to go to menu or settings or select .. then scroll till you find RINGER TONE (not to be confused with key tone). Select RINGER TONE and should be able to scroll down to select different ring sounds. One of the options will be OFF. On mine, it is 0. Select any one of the others to make it ring. There is no ON ... if you follow my drift.
Hope this helps Tricia in Bermuda
Aug 08, 2011 | Panasonic KX-TG2313W 2.4GHz Digital...
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Phone won't ring or alow preview of ring tones
DEAR FRIEND,YOU WILL HAVE TO CHANGE THE RINGER OF YOUR PHONE. IF AFTER THIS & THE PROBLEM STILL OCCURS,YOU WILL HAVE TO CHANGE THE FLEX OF YOUR PHONE.
Feb 23, 2011 | Motorola Mobility W385 Cellular Phone
I am having problems with my phone not ringing It sayes it is muted please help
make sure phone is off (no dial tone or caller) , then hit program it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones and off hit select (and choosing a ring tone)
Feb 13, 2011 | Vtech 9009111 Cordless Phone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Motorola H350 Bluetooth
because certain headsets have their own tone, no matter what tone you have set on your phone, you need to set it up in the options in the bluetooth headset settings in your phone.
Aug 31, 2008 | Motorola Mobility H350 Wireless Headset
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Motorola Mobility W385 Cellular Phone Logo
209 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
