Question about GE Refrigerators
Puddle of water TBX18SI model
we do not have a manual, don't know where the drain or overflow pan is
  • Mike Smith
    Mike Smith May 11, 2010
    Is the water on the side of refrig , inside the fridge , under the fridge ? Have you checked the water valve if the fridge has an icemaker ?
hotuna
  • 288 Answers
SOURCE: Drain Pan overflowing
Refrigerators use different methods to eliminate the water, but they all use evaporation of some sort.This works,as most of the water in the drain pan comes from melted ice on the evaporator coil during the defrost cycle, and this is not very much. It sounds like you have excessive water in the pan. You stated the freezer/fredge is working properly. The condenser fan is running, I assume. Cleaning the dust off the coil will help the air flow. Most residential units do not have heating element in the drain pan. Your problem sounds like you are getting too much water in the pan. Have you noticed excessive ice in the freezer? Are the door gaskets in good shape. Does the unit have water and ice in the door? If so, where does the drain to, and has there been high usage of this?
Posted on Nov 11, 2007
aborcass
  • 2651 Answers
SOURCE: Water overflowing of defrost water pan
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 02, 2008
docjohn174
  • 943 Answers
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Posted on Sep 11, 2008
  • 151 Answers
SOURCE: kenmore model 253.65812502 water leaks from
Do you live in a area where it's humid. Check if the doors seals are sealing properly.
Posted on May 14, 2009
aasc
  • 1606 Answers
SOURCE: drain pan over flowing
The rubber seal on the water filter is bad . Replace the filter in the bottom kick plate . When the filter goes bad , water will drip into the drain pan , causing it to overflow .
Posted on May 12, 2010
Why does drain pan overflow? How is water in pan suppose to go away before overflowing?
Are you sure it is the drain pan overflowing? If water is appearing on the floor every few days, it may not be getting to the drain pan (evaporator tray), due to a blocked drain channel. The evaporator tray will normally cope with the daily amount of de iced water of a frost free fridge/freezer.
Mar 07, 2015 | Refrigerators
My refrigerator is leaving a puddle under the freezer - it is a side by side. There is not a drip pan in the bottom. Should there be a drip pan? What could be causing the puddle?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Hotpoint Refrigerators
Our freezer is defrosting and leaving a puddle of water on the floor. The unit is 1 yr old..
Don't know what type of model you have but most have a hole for a drain in the back bottom of unit to drain down to a pan under the unit. Look for this drain opening. It's either clogged with food or frozen water. Clear away debris and pour boiling water through and see if it drains into pan under unit. You may have to do this several times.
Jul 15, 2010 | General Electric PSHS6RGXSS Stainless...
Drain pan over flowing
May 12, 2010 | Kenmore 57029 Side by Side Refrigerator
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Air Conditioner (RUUD model: UBHC-14J06NFD) is leaking water from bottom. It is causing a major puddle in Air Intake area.
The condensate drain line/pan is clogged causing the condensation to overflow the pan.
The easy way to fix that is attatch a powerfull wet/dry shop vac to the end of the drain line and such out whatever is causiing the clog. Also take off the panel to the evaporator coil and clean out the pan with the shop vac.
To double check that the clog has been removed, pour a gallon or two of water into the pan and ensure that it is draining properly.
Oct 11, 2009 | Heating & Cooling
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
Refrigerator water drip pan
Sep 11, 2008 | Refrigerators
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Refrigerators Logo
334 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
