Question about Whirlpool Washing Machines
Need a manual for Whirlpool AWO 10561 washing mashine
Master_Tech
  • 770 Answers
SOURCE: washing machine
whats your email i can send you the service manual
Posted on Jul 30, 2008
jonniewalker
  • 1029 Answers
SOURCE: fault codes f 13 Whirlpool Washing Machine AWO/D 5716
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Posted on Jan 29, 2009
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
SOURCE: Whirlpool AWO/D 4505 Washing Machine
The 'Clean pump' light has come on, on the above washing machine and it will not work. Any idea how to clean the pump or do I need to contact a whirlpool engineer?
Posted on Jun 27, 2010
Machine is washing and spinning ok just door wont open when its finished
Either the control board is defective or the lock actuator is defective or jammed.
Jan 21, 2017 | Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
I need to download user manual of front load washer Model Whirlpool AWO 9561
Dec 09, 2010 | Washing Machines
Machine stopped showing F11 as fault on screen. No detail in the book as to cause or solution to this fault. Machine is a whirlpool AWO 10561
F11 Motor control unit internal failure MCU board failure or broken wire. Check that harness for loose connection to that white box on the left. That is the MCU. Get a tech manual for your machine HERE fe0b7a2.jpg4c1535c.jpg
This might just be a loose connection. The MCU pictured here is the white box on the left and above
The tech sheet is behind the kickplate also and it will give you the data you need for your codes.
Jun 02, 2010 | Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
546 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
