Question about Maytag Dryers
Maytag Model DG312 not drying - Maytag Dryers
  • 525 Answers
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch, If available.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di3018&PartID=3018 Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di3479&PartID=3479 Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di483890&PartID=483890 On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Other components that could keep it from drying.
Washer not spinning dry enough
Restricted Venting
Make certain that unrestricted airflow is available.
Blower: must be tightly attached to motor shaft.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1245880&PartID=1245880
Cycling Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di484074&PartID=484074
Gas Valve
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1689&PartID=1689
Motor Centrifugal Switch
http://www.repairclinic.com/SSPartDetail.aspx?s=t-dg312-%3d%3di1245851&PartID=1245851
Posted on Sep 08, 2009
Dryer ldg490 will dry on timer dry but runs forever on permapress (not much heat) what sensor is bad ?
sounds like bad timer points, they tend to burn and get stuck on some places ?
Oct 02, 2014 | Maytag Dryers
Broken wire from the igniter on a maytag dg312 gas dryer
Hello Randy,
If the wire it broken on the actual ignitor with the ceramic base and the gray filiment,you could just replace that ignitor and keep that glorious 20 year old plus dryer going for years to come.The ignitor could be purchased at your local applince parts store for under $30 the part number is 279311 it also could be ordered online at;
assuredparts.com
apdepot.com
appliancepartspros.com
repairclinic.com
Gene
Aug 09, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas dyer model dg312 is on igniting hot surface is turning on but no flame
i am not clear on what you are saying. i think you are saying that the ignighter is comming on. if this is so then there are two coils on the gas safety valve. replace them both.
Nov 22, 2010 | Maytag Dryers
I have an old maytag dryer that wont heat. happened once before and i replaced something but cant remember what part it is a model number DG312 series & serial number 339062xa i am thinking it was one...
Hi, I have looked the model up and it shows it is a gas dryer.These round switches you are talking about are for safety reasons, You should have a wire connected to one side and going out the other.Pick you up an insulated wire with clamps on the ends at Home Depot, Radio Shack for sure and you can bypass these switches to see if the unit starts to heat. This is the best way to check a switch as we do this everyday in A/C repair. Process of elimination. Best of Luck to you and please keep me posted. Safety First.
Shastalaker7
Nov 27, 2009 | Dryers
Gas dryer is not heating now.
That unit should have a glow plug igniter. No pilot. Please be carefull lots of lent to catch fire. Good luck
Nov 09, 2009 | Heating & Cooling
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Need a wiring diagram for a maytag gas dryer dg312
If the old motor is still installed simply change wire for wire.
Jul 27, 2009 | Dryers
Maytag Dryer Model DG312 gas
Honestly, I must advise on getting a new dryer. A new dryer will run about $200-500 depending on which kind and where you get it. Repair on a dryer will cost roughly $125-$200 pending parts and labor rates if you decide not to do the repair yourself. But there is a way around those two options. Depending on your area, a Sears technician can come out to the home for $65 (pending location) and diagnose the problem and give you his/her estimate on how much the repair will cost. If you decline the repair, you may ask the technician for a voucher coupon for the trip charge that may be applied towards a new dryer from a Sears store priced at $399 or higher.
Mar 07, 2008 | Dryers
Dryers Logo
809 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
