Question about Samsung Televison & Video
I cant get my tv to recognize the second avi port
How do I format USB stick to recognize avi files
USB is already formated. It should popup a menu of options if it is working properly. If you want to "store" an avi file on the "stick", you should be able to do that just like any other hard drive. Do you see anything happen when you plug it in? If not you may have a problem with the stick or the USB port. I find this site very helpful
http://www.tomshardware.com/ good luck.
Mar 03, 2015 | AVI Audio Players & Recorders
Usb will not show avi movies?
One must remember that smart TVs are not computers. While they have a processor and can perform many computer-like functions, they are limited in what they can do to what the designers embedded in them. Many TVs can only read MP3/MP4 type encoding, and will not recognize other types such as .avi or .divx. Check your smart TV manual for a list of what file extensions are supported. If you have a computer, you can get converter software (often free) that will convert the file format. Then you can convert to a file format that is TV-friendly.
Mar 03, 2015 | Televison & Video
Files not show/recognized when connected to the tv and movies not playing
Your movies have to be converted into .avi format. There are many websites to download video format conversions depending upon your PC's operating system. Once you have found the right software, you will have to attach your Ext HD, then open each movie & click 'Convert to AVI'. Once completed, you can delete the original. If you need more help come back to me.
Apr 09, 2014 | Iomega ScreenPlay
Usb port doesn't recongnize .wmv .mp4, avi, (basically any video)
Check your manual and see whether these are supported.
Aug 19, 2012 | Vizio VT420M LCD TV
How do you play avi files with usb port
you need to know waht video format your TV support.
then use a video converter to convert the vieos you have to the right format and resolution.
Here is the Best video converter I've used.
Jun 05, 2012 | Panasonic TC-P50S30 - 50 1080P Plasma TV
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
Aug 14, 2010 | LG 42LE5500 42 in. TV
Dvd with usb port can not play avi
good day,
hope this link below will solve your problem.
nokia
May 29, 2010 | SanDisk Sansa e260 MP3 Player
Have a panasonic pv-gs19 that is not recognized on my computer. Use to have Windows xp and was recognized when using usb. Now new computer has vista and I was told by panasonic I have to use the 1394 port...
I have a Panasonic PV-GS9 mini DV Camcorder that is not recognized on my computer. I have windows Vista and I have it plugged in via my USB port but it doesn't recognize it and I do not have the disc. Please help me I have to put this recording in AVI format now.
Mar 05, 2010 | Panasonic PV-GS19 Mini DV Digital...
While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
Try resetting the video output. Follow the steps below:
  1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
  3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
  4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
  5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
  7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Thank you for using fixya!
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
I cant download youtube
The video conversion software (actually made by ArcSoft) will not naturally recognize FLV files. You will need a FLV to AVI converter - I use Riva FLV Encoder. Once the YouTube videos are converted to AVI, the video converiosn software for the GoGear should recognize it and convert the video. If the video conversion software is giving you a codec error - get codecs for FLV, AVI, MPEG-4, and any other format you may be using (Quicktime, latest version contains many of these Codecs).
Nov 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Televison & Video Logo
623 people viewed this question
Henry  Thomas
Henry Thomas
