Question about Philips AJL700
Philips ajl700 kitchen dvd player, won't turn on.
Hillips ajl700 kitchen dvd player, won't turn on. It has worked fine for 3 years now it won't turn on, nothing works
5 Suggested Answers
Tech5508
  • 40 Answers
SOURCE: No color output from philips 751/171 dvd player
Hello.
The RF modulator sends on a certain frequernzy(Channel) usally around channel 36 on UHF. If there is a adjustmen screw on it try and turn it util the picture disapears and then search for it on the tv again just to make sure nothing else is interfearing on the channel the RF modulator is sending on now.
An alternative if there is no adjustment on your RF modulator would be to change the frequenzy on your VCR or other devices attached to your TV that might send on the same frequenzy as your RF modulator.
Regards..
/Tech5508
Posted on Feb 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Philips DVP642 DVD player. It has worked
First try a soft reset... unplug for 20 minutes.
Otherwise - the laser is dirty or misaligned.
A Repair shop can clean and align for about $50.
It takes specialized equipment and templates to align the laser - not something you can do on your own.
Lens cleaner discs don't work.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Feb 27, 2010
SOURCE: karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
Posted on Sep 27, 2010
bugoy31
  • 1238 Answers
SOURCE: I turned on my Philips
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Power supply looks like this:
Please follow this step on how to fix that problem on your own..
  1. Open the back cover of your TV.
  2. Look at the power supply board..Its normally connected to the power cord..
  3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
  4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
Try to watch this video about capacitors and how to replace it...
I hope this solution will be helpful...
Thanks for using fixya...
Posted on Aug 16, 2011
My philps Dvd player won't work correctly
From the description the pladder motor is bad, " disc spins on" or it is missing the 5 volts that drives the motor. The laser pickup that pops up and down appears to be working fine.
Apr 13, 2012 | Philips PET741 Portable DVD Player
I purchased a Philips PET707 portable DVD player. It worked fine for a while, but now, when I put a disk into it, it just says
Replace the player, the laser pickup assembly is the problem, overtime it becomes weaker until it can no longer read the disk.
Mar 31, 2012 | Philips PET707 Player
My phillips dvp5140/37. video player ,stops
Does the player ask for a password?
If it does look in the manual or contact Philips on their website.
This helped me a lot once.
Jun 13, 2010 | Philips DVP5140/37 DVD Player
I can't get the tv part to play. Do I need a
This equipment catch regular tv air signal?Than yes.
Sep 29, 2009 | Philips AJL700
Asking For Password Then Won't Finish Load
here is what i did to fix this
1 go to Philips,com
2 find your dvd type / model you have
3 down load the latest sortware / fermware file to a computer "its a .ZIP file"
4 unzip the file to your computer and burn it to a cd-rom disc
5 power up you Philips DVD load the ****
6 this vary importent you well see it it say UPGRADING - NO NOT POWER OFF
wait for it to finish first it took me about 3 minuts
7 after it was done it worked just fine
Sep 06, 2008 | Philips DVP3960
DVD PLAYER WILL NOT PLAY REGION 2 DVD'S
i am also looking for a multi zone code for my philips ajl700 , ajl 700 .I just changed my dvd player over useing a code i found on this web site. Every model seems to have a different code.
May 23, 2008 | Philips AJL700
Dvd/cd player will not play the dvd
open your dvd player and check the flex cable that is connected to lens from module replace that flex but if he did not read again the cd try to replace the lens.
Jan 29, 2008 | Philips AJL700
Dvd kitchen radio under the cabinet
The back light for the LCD is dead. I took apart my Grandfathers player the other day and put a light behind the screen and could see. I am trying to either find a new LCD or the backlight for it.
Nov 15, 2007 | Philips MDR700
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Philips AJL700 Logo
311 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
