Question about Toshiba 32AFX61 32" TV
Picture is clear, but very green-- Toshiba 32AFX61
  • 378 Answers
Check the matrix board, usually loose connection of trnsistor lead is the cause. resoldering and check driver transistor.
Posted on Sep 06, 2009
How do u fix green pigmentation on a toshiba 32C110U 32 LCD TV
It all depends on if the pigmentation is permanent or due to static voltage within the circuit , in the RF circuit or fault in circuit.Use a cleaner to wipe and check if this changes , also check using the DVD and if the picture is clear then check your cable.
Mar 11, 2012 | Toshiba 32C110U 32 in. LCD TV
Washed out colors dominated by green and purple
There is fault on the chroma section and can be related to the board . Also a proper alignement cannot be ruled out unless the fault is seen in detail and so it is best to seek a consensus and estimate before you proceed , not to tamper unless there is a clear direction from the observation.
Dec 03, 2011 | Toshiba Televison & Video
No sound. changed channels and adjusted volume settings but not joy. video works fine.
If you are on a satellite system, well they have a recurring problem that cuts the sound off. You may only need to unplug the satellite receiver for 30 seconds. I have seen this happen so many times. Also be sure you have not inadvertly pressed the mute button. And be sure the speakers are on in the sound menu. The worst and last problem is a bad audio circuit failure in the TV.
May 28, 2011 | Toshiba 32AFX61 32" TV
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Jan 23, 2010 | Toshiba 36A41 36" TV
Toshiba 57HX81: Green works but Blue and Red seem to be out.
Do you still have reds? Is the image still clear though discolored? If so you ought to replace the blue bulb which has most likely failed. The part no for the 57HX81 model blue CRT bulb is TOSHIBA     23008753.
Jun 11, 2009 | Toshiba 57HX81 57" Rear Projection...
Green picture with horizontal green lines...
John,
First, Id like to know how old is your unit? Also, the lines indicates in issue with regards to the lifespan of your tube. The dominant green color has something to do with a malfunctioning ray gun of your tube. However, i had encounter a unit that was resolved by simply resoldering the circuitry of same problem.
Why dont you try to resolder the board first.
Response is highly appreciated.
chris
Mar 29, 2008 | Toshiba 32AFX61 32" TV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Toshiba 32AFX61 32" TV Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
