Question about Frigidaire Affinity ATF7000E Front Load Washer
I have a frigidaire front load washer, it and the clothes stink.
I have a frigidaire front load washer. The inside of the washer and my clothes stink. What can I do? I have tried several things: Changing the water temperature, several products and nothing seems to work. Is it defective.
  • 4 Answers
No, it probably just needs to be cleaned.
google "how to clean washer pump filter" - there's a couple of videos on youtube. (if you're lucky, your model will have an access door, if not, you unbolt the lower access panel to get at it.)
it's easy to do, and very effective. (there's no point "deodorizing" a pile of rotting lint, when you can remove it and solve the problem.)
this should be in the owner's manual of every front-loading washer, under "maintenance", but it ain't!
Posted on Jan 19, 2014
I have read that using Nu Fresh in a few of your loads will take care of this problem.
Posted on Sep 06, 2009
CLOTHES STINK LIKE MILDEW
I also have had that trouble and was told by repair man to use alot less soap and set machine for extra rinse.COLD water. Another thing that helps is a small amount of vinegar in bleach dispenser. Hope this helps.
May 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
Our 5 yr. old LTF2940ES0 reaks of mildew and is covered and stained with mildew on the inside rubber ring. It does not drain all the way after a cylcle, either. I have scrubbed and washed it with bleach...
The problem is the big round gray rubber seal and the ridges. I have this exact washer and had the exact problem. It stunk. There is a replacement gasket for $100+ that I purchased. (It's what the new ones come with.) It has no ridges and more holes to drain the water out of. It was a pain to replace it but it was well worth it. It is like having a new washer. We tried all of the bleaching, special powders, etc and none of that worked.
Jan 16, 2010 | Frigidaire GLTF2940ES Front Load Washer
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
STINKING CLOTHES front loading mach.
One possibility is to not leave the clothes in the washer overnight or they will have a little foul smell to them. We have a Samson washer and it does the same thing and it ranks close to the top on Consumer Reports. If this doesn't help have you tried going to Lowe's and ask someone in the appliance department to see if they can help. You may have already done this but call the manufacturer to see if this is a common problem and see if they have a solution. If they're not very helpful or cooperative let them know you will do a little "free" advertising for them in a nice way of course. I hope this helps. I'm having trouble with a Bissell shampooer not dispensing the shampoo and also not picking up most of the water. It's really aggravating. Have a great evening.
Jun 12, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
Switch from liquid to powder detergent, no fabric softner (I know...I love it too), clean the gasket and run a cycle with bleach only. Leave the door open whenever possible. This fixed my smelly washer, now if it would only spin!
Jun 02, 2009 | Frigidaire ATF6000ES Front Load Washer
what kind of washer?
all front load washers get this issue
the way to get rid of the smell is by doing an acid wash to your machine
set the washer to the highest temp setting (sanitize would be best)
mix in 1/2 to 2/3 cup of javex or white vinigar, either one will do it
run your washer through the longest cycle possible with no clothes in it
may need to be done more than once. and up to once a month
the smell is caused by leftover detergent and leftover fabric softner gathering on the interior shell and in the rubber boot at the door.
front load washers do not require much detergent at all, and even less fabric softner.
be careful on how much of these you are using, more is not better
this will help prevent the odor from comming back
as well when laundry is not being done, the front door should be left open a bit to allow air movement in the washer.
hope this helps
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Stinky washer
I had a similar problem with odor. I ran the washer on hot with a few cups of vingear in the detergent, bleach, and fabric softener trays and it helped a lot. Also, be sure to leave the door cracked open when you remove wet clothes, so the inside of the washer can air dry.
May 05, 2009 | Frigidaire Affinity ATF8000FE
Bad odor
glisten and affreash is the cleaning agents
besides this only way to get smell out is a complete inner and outter tub job but also try leaving both soap dispenser and door open for the air to dry up and vent the washing machine
Feb 24, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Washer door is locked and will not open
Unplug it for thirty minutes then plug it back in should reset it.
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
403 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
