Question about Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder
What is required to switch from steel to gas on light duty mig welders
  • 21 Answers
If you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Posted on Sep 06, 2009
I have a lincoln sp-100 welder and despite having a good ground the weld quality is just not there. Any help is appreciated
Let's troubleshoot this one:
1) Make sure you have the right polarity for the wire you are using: Innershield wire (no gas) ground clamp must be on the + side. Solid Wire (gas use) ground clamp to negative side.
2) If gas is used: Mild steel welding requires Argon/CO2 mix 75/25 or 90/10. Using pure CO2 you will create a lot of sparks and a lot of fumes. Stainless Steel welding requires a Trimix gas of Argon/Helium and CO2. Aluminum Welding requires pure argon. Any use of gas requires a steady gas flow of no more than 25 SCFH. If you use more than that or less you will find porosity on the welding.
3) Your work piece must be cleaned before welding (no grease, dirt or paint).
4) Check your machine welding chart for wire speed and voltage.
If you still experience problems with welding quality, check you input power voltage, make sure it doesn't fluctuate.
Goooooood Luck.
Aug 30, 2011 | Lincoln Mig Welder Trigger Switch Magnum...
My welder suddenly stopped feeding wire and gas when i push the trigger. i'm assuming that either there is a problem with the trigger signal or the duty cycle was exceeded. If the duty cycle was...
I found a manual that has a lot of information in it.These welders only have a duty cycle of 30% so that means you can only run them 3 minutes out of 10.They have thermo switches that shut them down before they get to hot.The house breaker needs to be around 50 amps at least I have a 125 buzz box and a wire feed and that's what I use.I would check the circuit breaker in the house to see if its tripped.I turn my mig on the side so that the shavings from the wire pushing wheels don't get pushed into the liner and clog the wire and make it jam.Well hope this helps.Thank You for choosing FixYa.com and good luck!
http://www.hobartwelders.com/service/owners-manuals/
May 15, 2011 | Hobart Handler 210 Wire Feed MIG Welder
Does welder need argon gas when using steal wirer
Hi:
If you are using solid mild steel core wire, yes you need a mix of gas Argon/CO2 75/25.
Only cored shielded wire do not required gas (also called innershield or flux cored).
Adjust your flow rate for the mild steel wire at 20 or 25 scfh, depending if you are welding inside or outside a shop.
Feb 05, 2011 | Clarke Power Products Clarke 130EN...
Clarke pro 90 gas mig welder wont penetrate
I have the same problem, please that´s some one knows how to fix this?
Apr 19, 2010 | Clarke Power Products WE6480 MIG95 Flux...
The Mars 180 MIG Welder Manual neglects to
Hi mate. Not sure on the power settings but the earth clamp is negative for gasless and possitive when useing gas
Mar 20, 2010 | Welding Tools
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Nov 02, 2009 | Welding Tools
WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Apr 05, 2009 | Welding Tools
SIP 195 MIG welder doesnt work
sounds like your welder has over heated and the Thermostat has come on
wait for 10 minutes and then try again
If that does not work fit a new PCB
Gilmore
Jan 01, 2009 | Computers & Internet
Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder Logo
248 people viewed this question
Top Lincoln Welding Tools Experts
Jim Goldsmith
Jim Goldsmith
Rob Emerson
Rob Emerson
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
