Question about Maytag PAV2300 Top Load Washer
Washer makes alot of noise
Washer makes a lot of noise. in spin cycle it is really loud. and we smell something of a burning smell
  • Maytag Master
  • 1,606 Answers
If the sound your hearing is a " roar " , then its the spin bearings bad and the smell could be the motor , working harder due to the bearing . Eventually , this bearing will wear enough , you'll start seeing water on the floor , gradually more and more . I would suggest you start looking for another washer , due to the cost of replacing the bearings and seal kit .
Posted on Sep 06, 2009
  • 296 Answers
Hi, Well my friend sometimes something works it's way into the pump assembly of the washer and this will make a clicking or scraping noise. When the motor drive coupler starts to wear down, the washer may also become noisy.Loose tub nut and drive block will be noisy in the spin only
Thanks! mannu_rakesh
  • 132 Answers
Time to replace the belt , might need a tub bearing too / tentioner pully might have froze . remove the back panel with the washer unpluged look to see if the tentioner is at its fullest possition if so replace the belt .
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
My drum has become very loose and it wont spin at all it still goes through the cycle and everything else is working fine could it be the belt or the bareing as it made a really loud noise then stoped...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 30, 2010 | Haier XQG50-QF802 Front Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer makes a loud noise during a normal wash cycle.
If it is a belt driven machine, then there's the smell. Lean it back a little, enough to fit a paint can under 1 corner and you can feel the belt right on the bottom. Feel for cracks, flat spots or a lot of black dust. Remove belt and make sure everything that it goes around spins free.
Mar 17, 2009 | Maytag PAV2300 Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
265 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
