Question about ViewSonic VA702b 17" LCD Monitor
My monitor only comes on for 1-3 seconds then turns itself off. When it is on everything looks good, sharp, correct data, etc. What can I do? Jim Lee JimLee_Sr@yahoo.com
  • 35 Answers
Please try and change the cables for the monitors
Posted on Sep 06, 2009
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
When turn on it flashes for about 1 second, then
this is probably a data problem...
try to access to monitors on-board menu (usually a small button beneath the screen)
if the menu comes up i would try in this order
a new vga cable
connected monitor to a different pc/laptop
wiggle your video card
try friends monitor on your pc
good luck, rate if useful
Oct 27, 2009 | Acer X241Wsd Monitor
My 19mvwk is saying no signal going to sleep
Check the data cable is properly fixed. Can you hear the beep sound while booting. Check the ram inside the cpu.
Jul 06, 2009 | AOC 19LVWK LCD Monitor
Monitor goes blank less than a second after turning on.
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
Dell Monitor comes on but no picture
The monitor isn't getting a signal from the computer, which is why the power indicator goes orange. There are two possibilities:
1) The computer isn't operating correctly. It may not be starting up at all when you turn it on, and you have a "no boot" problem to solve, or
2) The computer is working properly, shows all the signs of normal startup (hard drive activity, Windows startup sound from speakers, etc.). but video isn't reaching the monitor. There may be a problem with the video card (or on the system board if it's integrated video). Or the monitor itself is bad and not detecting the video. You can test this by connectng a known good monitor.
Jan 16, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
My Dad bought a NEC 1700v Monitor about 5 years ago. Its a good monitor and the picture/color is still good but it blacks out after it shows desktop for about 10 seconds. To get it to come back on, can...
This is a CRT monitor right? Do not open the case! There is high voltage stored in a capacitor somewhere in there and you could get zapped. You can buy good used monitors at Goodwill or a computer re-cycler for $20.00. If yours lasted five years you got your moneys worth. Did this monitor work correctly on other computers? If it did maybe you have a problem with your graphics card or something in the computer itself. Try a different monitor on your computer. If everything is OK with a different monitor then you know that your computer is good and that is not the problem.
Nov 30, 2008 | NEC Computers & Internet
Monitor will not stay on
Same boat 1.5 years old and the screeen will shut down in about 1-3 seconds as long as i turn it on.
Mar 31, 2008 | Gateway FPD1975W 19" LCD Monitor
Dell flat monitor E197FPf
This model has 4 CCFl's and one of these bad will cause the inverter output to drop off.. (Safety feature).. easiest way to check is by process of elimination plugging a good CCFL from a laptop screen or similar inplace of the 4 to find the one dropping out. If all check good Check the Caps as these like to fail as well. Good luck!
Jan 29, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
Stopped turning
Try removing the cover and looking for a broken belt. Make sure that the motor is spinning too. If you find a broken belt, let me know and I'll help you find a replacement.
- Jim
Jan 28, 2008 | Teac SL-A100 Turntable
Turns off and on by itself
Ok so its connected to your pc?
check settings on the monitor itself [if you'restill able to do that]
disconnect all your usb devices restart your computer and try again.
Is it in a cold room ? that might be the problem.
Is it in the same powerbar as your computer ?
I'm not sure but if your power outlet where you connect it is simply looped to the rest that are in use [lazy electrician] then it might turn off because a power shortage.
Good luck
Dec 21, 2007 | Acer 19" LCD Monitor
ViewSonic VA702b 17" LCD Monitor Logo
110 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
