Question about Baby Gear
Will only turn right will not turn back left why?
  • 419 Answers
More than likely, your wheel assembly has got some dirt in it. If it is possible, remove and clean the whole unit and ensure that you put in some lubricant, (something like vaseline would be handy) don't use WD40 though as this can attract dust.
I hope this helps.
Posted on Sep 14, 2009
  • Liz Wanden Sep 14, 2009
    I hope this helps.
Western plow will not go left
There is a hydraulic block/valve. Replace it.
Jan 03, 2017 | Cars & Trucks
Power wheelchair won't turn right, back tire squeals
Have you completely disengaged the wheel locks? Check for worn wheel bearings.
Apr 19, 2013 | Invacare Health & Beauty
Problem with turn signal when headlight is on
this sounds like a earthing problem , so check the wiring for the head lights, see if any wires are trapped between something, bare wire touching car body , anythingthat doesn't look correct, could also be the indicator lever itself with a problem , but check the headlight wiring first
Jun 03, 2017 | 2002 Chevrolet Express
2003 explora sport, blinkers: left turns on right and right turns on left wth.
check the bulbs if someone install a signal eliment bulb in a dual outlet it would back feed the system
May 26, 2012 | Ford Explorer Sport Cars & Trucks
How To Install Replace Windshield Wiper motor on a Honda Odyssey
Put the right side wiper on only. Turn on wipers. When the wiper moves all the way to the left and starts to go back to the right turn off the ignition with the wiper switch still on. Remove the right wiper arm and install the left wiper arm in the far left of the wiper movement. Turn on ignition and allow the left wiper to go all the way back to it's rest location at the bottom of the windshield. Turn off ignition and install the right side wiper arm. This will give you a start to properly set the wiper arms.
Apr 12, 2012 | 2003 Honda Odyssey
Grinding noise changes with speed stops when turned right. replaced left front wheel bearing. noise is still there. whats wrong ?
Does sound stop when you turn LEFT?
Turning RIGHT puts the heavy load on the LEFT front wheel.
That initially STOPPED the noise, correct? So why did you change L?
Turning LEFT puts the load on the RIGHT. Did you change the RIGHT?
Let's say this:
If turning RIGHT stops the noise, it's the RIGHT one that's likely bad.
If turning LEFT stops the noise, it's the LEFT one that's more likely bad.
Make sense? Turning RIGHT loads the LEFT wheel; and vice-versa as the WEIGHT SHIFTS AWAY FROM THE TURN.
More than likely it is what some folks call a CV joint problem, not wheel bearings. Try backing up and then going forward to see if "clunking sound" or a sharp "bang" is heard. Wheel bearings and CV joints only work if smooth. Sometimes a BEARING RACE is bad. Also, a bad spindle / part of the CV joint / transaxle assembly worn or badly machined. If in a WET ENVIRONMENT especially, u may want to try marine grade grease or teflon-added grease.
Does sound come from POWER STEERING PUMP area?
Nov 30, 2009 | 1997 Buick LeSabre
Left side turn signals ( front & Back) won't work
Check the bulb for the actual indicator light on the dash
Jul 16, 2009 | 2000 Harley Davidson FXD Dyna Super Glide
Right side turn signals don't work.
if bulbs okay check fuse is good you got faulty turn switch or bad ground.
May 09, 2009 | 1998 Mercury Mountaineer
Baby Gear Logo
26 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
