Question about Riso RZ220 Duplicator
Paper Sticking to the drum
Hi, I have a Ricoh Priport JP 1210. I keep getting a 'Paper Wrap Jam' where the paper sticks to the drum. I've changed the master several times and no joy. Any ideas?
  • Anonymous Mar 26, 2014
    it is more ink in the drum
  • Ben Sproule Jan 21, 2017
    If you have heavy ink at the top of the page it can cause this. Try shifting the image lower especially if you have a lot of ink at the top.
  • 389 Answers
Check in what condition separators drum.
Posted on Sep 20, 2009
Yes, paper don't getting out of printer as is jam. If this is happening first you should check is how you storing your paper. Paper is likely to easy cumulating humidity from the air and need to by store in warm and dry place all the time. If you use incorrect stored paper that will sticking to the rolls or rolls will slide on paper which mean "paper jam".
Aug 17, 2015 | Office Equipment & Supplies
We have a Ricoh Priport HQ9000 which keeps jamming at the paper entry and we are getting a small mark in the middle of the paper
check the rollers well. sometimes they get grime an dust into them and stick or roll rough an hard or not at all. just a touch of spray cleaner works.
Jan 30, 2015 | Ricoh Office Equipment & Supplies
Priport jp 5000 thinks it's jamed after each
Look for the sensors which are mounted a little before the roller as the paper is fed the sensor will detect -- therby called INDETECT sensors.
So it can be due to misaligment of a failure and must be checked with a multimeter.
Aug 31, 2011 | Office Equipment & Supplies
Ricoh priport jp 1010 error code E 02 explain this code to me.
when powering on, ricoh priport jp 1050 indicated 02
pls help how can solv
Jun 10, 2011 | Ricoh Office Equipment & Supplies
I have a Ricoh Priport VT2250 duplicator. I keep getting an error
ls lt an image problem? image problem can be occurred if the solid black part of the image is on top. try to reverse the image by scanning it invert the image on the other side meaning the solid part be placed at the bottom.
May 26, 2010 | Ricoh Priport VT6000 Copier
Paper jam message, remove the paper from drum
Try cleaning the feed rollers with soap and water and a damp cloth and see if your situation improves. sounds like the machine is missfeeding but your description was a little vague.
If it does improve youll need new rollers.
Also try flipping the paper over to see if improves.
Lastly does the paper size displayed on the screen match what is actually loaded? if not... correct as nessesary
Good luck
Apr 18, 2010 | Ricoh Office Equipment & Supplies
Error message E02
Ricoh Priport VT-2100/2130/2150/2300/2500/6000
E 01 Malfunction in cutter section: The cutter motor does not reach both right and left cutter position detecting switches within 2 seconds 1) Drive wire cut
2) Drive section malfunction
3) No power supply E 02 Malfunction in the paper table drive section: The lower limit sensor or the paper table height sensor is not turned off even though the paper table UP or Down signal is applied 1) Drive worm gear broken
2) Mounting screw of the worm gear broken
3) No power supply
Apr 01, 2010 | Ricoh Priport VT6000 Copier
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Hello sir; Go make a copy let paper jam again, do not remove the paper, check the jamming paper area see there have any paper chip stuck in the paper path, clear it, otherwise cleanup roller with alcohal.
Jul 20, 2009 | Ricoh Aficio MP1600SPF Copier
Paper Jam at exit holder
Hi jam_es_2001:
The roller in the maintenace kit applies a thin layer of oil to the image drum. When the image is applied to the drum the oi prevents the image from sticking. The cleaning blade cleans the drum after the image is applied to paper. After the image is applied to the paper the drum is cleaned by the cleaning blade and new oil is applied to the drum for the next image. Check the roller in maintence kit to see if it is dry, if it is replace the maintenance kit.
Hope this helps
Jul 16, 2009 | Xerox Phaser 8400 Laser Printer
385 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
