Question about Lexmark X5650 All-in-One InkJet Printer
Describe your lexmark 5410 troubleshootsetup Problem The printer won't print documents sent from my imac even though the cords are connected as shown in the set up illustration.
I cannot use the scan function on my X5470--specifically, to scan documents into PDF format. "Cannot retrieve Application List" is the messge shown. How do I repair this function?
Make sure the Lexmark OCR scan software is installed on your computer. The software allows you to scan your documents to PDF file. The software is only available on the installation disc that came with your Lexmark printer. If you don't have the disc, please contact Lexmark Technical Support Center for assistance.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
Have bought new Hewlett Packard computer Model #200-5220. Tried to install a Lexmark X2330 printer. Went into control panel ''install a printer' - highlighted Lexmark, but in the next column the model...
Disconnect the printer from the computer. Insert the driver disk that came with the printer into the CD/DVD player of the computer. Follow the prompts and install the software for the Lexmark. When it is finished installing, connect the usb cable to the computer and try printing a test document.
If you do not have the disk that came with the Lexmark, go to the manufacturers website at www.lexmark.com and click on support. Then find the download software/driver option and enter your model of printer. Then follow the prompts to download the file to your computer and install it. when it is finished installing, connect the printers usb cord to the computer and try printing a test document.
Some drivers do not come with your operating system and need to be installed before your printer is connected. Once the drivers are loaded the pc will automatically recognize the printer once connected.
Mar 28, 2011 | Lexmark X2330 Printer
I have two computers on my network, an iMac and a PC running Windoew 7. I recently purchased the Lexmark Pro901 and installed it on the network. It(the Lexmark Pro901) seems to connect fine to the network...
It could be a software issue. Try to uninstall the existing Lexmark Pro901 driver from your desktop pc by going to Start menu -> Programs -> Lexmark -> Pro900 Series -> Uninstall Lexmark Pro900 Series. Reboot pc when prompted.
Now, check your Windows 7 if it's running on 32-bit or 64-bit by going to the Start menu -> right-click on Computer -> Properties. Take note of the System Type.
To reinstall, download the Lexmark Pro900 Series driver using the links below: - Lexmark Pro901 driver for Windows 7 32-bit - Lexmark Pro901 driver for Windows 7 64-bit
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Jan 04, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I'm trying to set up my lexmark printer to my new imac, i have installed the cd and set up the printer wirelessly but when i go to print it says there is a error and the printer is off line even though the...
You have to convince the computer the printer is online. Is your computer capable of wireless connection to the printer?
I solved this problem on my system by removing and reinstalling the print driver. My system is a little different, I have my printers wired to my network as stand alone.
Make sure you have the proper drivers - you probably already have .... double check ... www.lexmark.com/support and make sure your printer is compatable with your operating system
I tried to give you some ideas ...
Feb 21, 2010 | Office Equipment & Supplies
Lexmark 5410 will not communicate with my mac or pc laptops
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Mar 02, 2009 | Lexmark X5495 Printer
When printing documents from my PC documents always sent to queue
Go to control panel, printers. Set your defaults there. You probably have spooling enabled. Uncheck it and your print job will go to the printer, rather than to spooling. Spooling is like rolling the print job up on a spool until the whole thing is processed, then unwinding it to the printer.
Feb 17, 2009 | Lexmark X3550 All-In-One Printer
Cant make prints lighter or darker
There are two ways to do this. One is to change settings in whatever application your are using. Increase your font size or bold your font (if you're talking about a document.)
The other way is to change your printer properties. Go to your printing preferences (from your print dialog or from Start->Printers and Faxes->right click on Lexmark 5400 Series->select Printing Preferences) and increase your Print Quality.
Steve
Jan 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper sensor, I think
check the cable first..and do a test page, if you can without the printer connected to anything.
then, if that all works, we can look elsewhere, no?
Mar 06, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark X5650 All-in-One InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
