but it works fine on my big pc, but i need it to work on my lap top cuz the screen on lap top is broke, i know i need to ajdust a setting but how can i if i cant see the screen?
connect the big monitor to your Lap top, then press the Fn key and hold while pressing the monitor sw. key , this key has rectangle marked shaded and not shaded.
Hello, you can try this... Connect your laptop with an desktop monitor throughVGA cable.... then Click on start>> goto control panel>> Double click on Power Option>> Under Power Scheme it should be Poratble /Laptop >> Select Never under System Standbye, Trun off Monitor and Turn off Hard Disk.
Thank you for contacting Fixya support, please rate if that helps!!
how do you tune a relisys tv I have done an auto tune but need to tune manually fine tune has a...
(More)
how do you tune a relisys tv I have done an auto tune but need to tune manually fine tune has a limited band
hello all! my name is theodor and I have a problem with my Relisys lcd tv monitor 1720.I need to bye...
(More)
hello all! my name is theodor and I have a problem with my Relisys lcd tv monitor 1720.I need to bye some neon tubs for tv screans.2 small and 2 big.This neon's flache the rate behinght the screan.I wand to order or to by this neon's tubs. thanks for the halp.
