Question about Epson Stylus C88 InkJet Photo Printer
Epson Stylus COLOR 680. INK Level Status Indicator does work
Based on this I cannot see or determine the level of the ink in either the Black or Color Cartridge nor which one needs replacing. I have now XP System on my Computer. Tthe problem seem to have occured sine installing XP.
Epson Stylus COLOR 880 will not show ink level on computer Window XP
Go to epson web. Download updated driver and "Status Monitor" software.
Feb 18, 2013 | Epson Stylus 880 InkJet Color Printer
I have an Epson CX4800 printer. It won't print because there is low ink. My laptop indicates that the ink is low, but won't tell me which color it is. How can I connect the two so that I know which ink is...
What OS are you running? Did you install the full Epson software before you connected the printer to the computer? Is the Epson Status Monitor running on the computer?
If you didn't install the full software or installed a generic Windows driver, uninstall the printer. Then disconnect the data cable. Reboot the computer and go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1326618163.1304563464@@@@&BV_EngineID=ccfkadfdhhmeimgcfngcfkmdhjidfmh.0&cookies=no&oid=58606&prodoid=56291067&infoType=Downloads&platform=All . Download and install the appropriate file from the section marked Drivers and Utilities Combo Package.
If you have a Windows OS, if the Epson Status Monitor is running, the icon for it should be present in the lower right hand corner of the screen (status/Notification area). In Windows 7, it may not be immediately visible, click on the double arrow symbol. Then double-click on the Epson Status Monitor icon and the status window should appear with the ink level indicators in the bottom half of the window.
For a Mac OS, open the Applications folder, then select Epson Printer Utility. Select your printer and click OK. Then select the Epson Status Monitor to get the ink level window.
I hope this helps.
(this is generally faster than using the No Ink spot inside the printer. However the ink levels are approximate.)
May 05, 2011 | Epson Stylus CX4800 All-In-One InkJet...
How could i know if my printer runs out of ink?
Your Printer's Status Monitor tells you when the ink in your ink cartridge is about to run out. However, the Status Monitor is not always accurate. If, you turn off the status monitor, the only sign that will tell you that your ink has run out is that if your printout has white streaks or lacks the other colors.
Nov 16, 2010 | Epson Stylus 680 InkJet Color Printer
After changing the ink, the red light is still on.
epson stylus photo R200 printer the two red lights are flashing can get it to work help
Jul 18, 2010 | Epson Stylus Photo R200 InkJet Printer
I've just installed both a new black cartridge and a colour one but after having to clean the heads a number of times to try and get the print quality back up to scratch the printer is now refusing to do...
.. is the light flashing alternate? if yes, then the printer porous pad need to be replaced and reset ink counter.. install your printer driver and status monitor and you should be able to find out whether it's the ink empty or maintenance needed. For this model.. I am sure your waste ink counter is full...
May 20, 2010 | Epson Stylus 680 InkJet Color Printer
Middle of three buttons permanently on red
Did you mean ink light permanently on? See status monitor. Is all chip (ink tank) recognized? Or may be some chip reach "ink out". Try to use another ink tank (new). If you wish to refill used ink tank, you must reset ink counter first.
Sep 28, 2009 | Epson Stylus 680 InkJet Color Printer
820 ink problem
Hi Evestal,
I've noticed the same thing on my Epson Stylus Photo 820 ink status monitor. If it's set to use only black ink, then logically it shouldn't actually be using any color ink other than when it does a cleaning cycle. Truth is... the built in monitor counts at the same rate for color and black regardless of the true levels. So, unfortunate consumers are likely to restock prematurely on expensive cartridges if they aren't aware that monitor is counting prints, and not actually measuring ink.
I've bought refill kits made by JetTec at Staples and they make a Re-Setting Device for cartridges. Lately my local Staples have stopped carrying this brand but I'm know they're available online. The re-setter is a little plastic device with and LED light that changes color after you match up it's little metal prongs with the microchip on your cartridge to indicate that it has been re-set. Just follow the directions that come with the re-set device. This is also a good way to get the last remaining bits of ink out of cartridges when they're low. The Epson print counter stops you from printing once it "thinks" it's out of ink but the reset device convinces it otherwise untill you really do run out.
Hope this helps. Good Luck.
Aug 05, 2008 | Epson Stylus Photo 820 InkJet Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus C88 InkJet Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
