Question about Denon AVR-2106 Receiver
Denon 2106 I will be listening to music or a dvd and all of sudden the speakers will shut off. I turn off the speakers and then back on and they will work for a while before it starts again. Any help would be great.
  • Anonymous Jan 01, 2008
    My 2106 has a similar problem. When it's on, it arbitrarily does one of three things. Sound through the main zone speakers will suddenly cut out, although zone 2 speakers still have sound; main zone speakers suddenly cut out and sound is replaced with high pitched whine; or sudden loud scratchy static will come out of main zone speakers for about 5 seconds followed by a pop from each main zone speakers. These are all inconsistant and arbitrary, effecting only main zone speakers, sometimes three times within half an hour, other times only once all day. Any ideas? Thanks.
  • Anonymous Mar 30, 2008
    My Denon 2106 does the same thing. While playing the TV or DVD the sound will cut out. I turn the system on and off and it works for a while and then eventually cutting out.
Try making sure the plugs are snug. Always helps me!!
Posted on Dec 16, 2007
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
Jul 20, 2013 | Denon AVR-3806 Receiver
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Crackling sound from denon avr 2106
I think you may have a blown speaker.
Sha'ul
Jun 25, 2009 | Denon AVR-2106 Receiver
Denon avr-2106 getting hot shutting down
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Keep us posted,
Dan
Mar 10, 2009 | Denon AVR-2106 Receiver
Problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Mar 01, 2009 | Denon AVR-2106 Receiver
Denon avr 3000 speaker B is off ,is theres a code to turn it on
I have a Denon AVR-3000 and want to turn on the B Speakers. I have hooked up my subwoofer to the B connections on the Denon since there is not a subwoofer connection. How do I turn the B speakers on without a remote
Jan 27, 2009 | Denon AVR-2106 Receiver
HAVE TO UP VOLUME ON DENON 2106 TO HEAR ALL AUDIO IN NIGHT MODE
There should be a volume adjust on the center channel. This is done by the remote exclusively. You may also wish to compress the sound using the dynamic range compression button or so labeled.
Aug 31, 2007 | Denon AVR-2106 Receiver
Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Jun 05, 2007 | Denon AVR-2106 Receiver
Denon AVR-2106 troubles
If the surround back is turned on,on the receiver,then the 7CH stereo will activate the 2 rear,but if it's off on the receiver the 5CH on the remote will do the same. I don't know much about the unit changing from 7CH to game,rock Arena etc.that i know will happen if u press the DSP simulation found @ the 3rd. top right button on the remote.
Jan 16, 2007 | Denon AVR-2106 Receiver
Denon AVR-2106 Receiver Logo
123 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
