Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a Whirlpool Cabrio WTW6600SW2 top loader washer. It keeps flashing F50. What is causing this and how can we fix it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F 50 flashes when the motor rotor position sensor (RPS) senses no rotation(Motor Stalled). Does basket turn freely? If not, make sure bottom shipping pack has been removed. Remove the basket and look for foreign object. If basket turns freely, then perform the below mentioned diagnostic test--
Motor Circuit TEST
This test checks the wiring to the motor and rotor position sensor; and the motor and rotor
position sensor themselves. NOTE: Drain water from tub.
1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this step failed.
2. Unplug washer or disconnect power.
3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
4. Remove the console to access the machine/ motor control assembly.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6. If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range shown in the wiring diagram on page 7-1. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to
step 7.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical
connections, reassemble stator and motor cover and repeat step 1.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. If there is continuity, go to step 11.
If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 06, 2009
Hello~ We've been struggling to repair our Whirlpool Cabrio washer - Model - WTW6600SW2. We received the codes F50, F72 and just F - we replaced the stator motor and RPS sensor kit; however, we are...
Hi
Please check this list of codes in whirlpool cabrio.You will get a detailed idea about code F 50 and the test to be performed:-
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio wtw6600sw2 f50 code.It spins freely.What now?
Any time you get a F-50 code on one of these, Whirlpool recomends you replace the control, wire harness, and RPS sensor if the tub bearing main shaft aren't binding.
Dec 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I need the service manual for a Whirlpool Cabrio WTW6600SW2 to find out what the code F50 mean and how to replace RPS sensor.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Silverdragon posted on here about the Whirlpool Wtw6600sw2, cabrio giving me the F50 code on how to solve it,--F50 - motor stalled The biggest problem with this machine is the rps sensor. If you pull the...
Tip mch back and locate the lg allen bolt in the center of the magnet and remove counterclokwise. The motor is actually a large magnet that revolve around a stator, a series of windings. Pull hard and place magnet away from any metal. Once off, remove the bolts holding the stator to the base and on the reverse side is the rps sensor. It looks like a wedge and is clipped onto the stator.
May 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code f 50 on cabrio WTW6600SW2 what is the most likley cause
Silverdragon posted the following yesterday about this issue...
http://www.fixya.com/support/t4267679-wtw6600sw2_cabrio_giving_me_f50_code
F50 - motor stalled The biggest problem with this machine is the rps sensor. If you pull the motor cover you can get to the rps. Then take the rps on and off about 5 times to remove a factory coating that keeps it from making the contact that it needs. For some reason the machine will work fine for several months after purchase before this occurs. After you do this it works fine. F50 f51 f70 codes
Mar 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600sw2, cabrio giving me the F50 code. Any ideas as to what that means?
Mar 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Sep 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washer keeps flashing code F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Jan 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio code F50
I also had an F50 code on my Cabrio top load washer. Went through all the diagnostics, removed the tub, checked the motor, etc. After a lot of research, purchased a new control board (part #W10189966) and....it works even better than before....no more noise and spins perfectly. Very easy to install (3 screws and one bolt.) Please don't waste your time (like we did) checking all these other areas of the machine. The part was $155. (google it for best price new) and worth it if it will last another year or more...
Nov 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
