Question about Sangean ATS 818 AM/FM/SW Radio
Power problem i removed the subject battery without switching off. now i can't power on. the only signal on the lcd is a key sign.
  • 2ndamateur Jan 19, 2008
    Note my siimilar problem posted (2nd amateur). Happened after power co. had turned power back on after working in the nieghborhood. CCrane (vendor) estimated repair at $95 plus shipping so I've been looking at their catalog with an eye towards replacement instead. May call my household insurance carrier to see if they will re-imburse. Good Luck.
Look at right side of radio. Just above the volume knob is the keypad lock switch. Just switch it to the other postition. Should work fine.
Posted on Jan 22, 2008
My headlights stay on even when key removed but the turn signals still work
You might have a bad ignition switch. Do the other accessory power features stay on too? Eg .... Radio, blower fan... Do the turn signals still operate when key is removed? But a bad multifunction switch (turn signal, headlight switch) coukd also be bad.
Dec 11, 2014 | 1997 Pontiac Sunfire
My 1992 Toyota 4x4 pickup key won't turn all the way off without disconnecting the battery. What could cause this?
is this a console shift? if so its most likely not getting the signal that its in park. There is a switch on the shifter that wont the key be removed without the vehicle being in park.
Oct 12, 2014 | 1992 Toyota Pickup
After having disconnecting the battery in my Chevy
The turn signal clicking sound comes from the driver radio speaker .Disconnecting battery without using back power supply can cause problems .Does the radio show loc ?
Battery Disconnect or Replacement Problems
Being able to roll down the windows with the key off is a function of RAP - Retained Accessory Power .
Retained Accessory Power (RAP) is a power mode that permits the operation of selected customer convenience items for 10 minutes after the ignition switch is turned OFF. RAP power mode is enabled by the BCM.- body control module .Disconnecting the battery caused something to power down an not wake up . The dealer should have been able to hook up Tech 2 scan tool an tell that . Without looking at factory service info . i believe the BCM sends a wake up signal to the radio , that's just a guess . I would need to know the year of your vehicle to check .
Jan 07, 2018 | Cars & Trucks
Programming keyless remote
Below is a couple proceedures on the subject --first one sets your personal security code in case you lose your Fob or if the battery should die the second one is ASSIGNMENT of a Key Fob to the bike
Below
mail_dir.ashx?url=http%3a%2f%2fwww.fixya.com%2flxp.gif%3ftype%3dimpression%26mailid%3d204&met=0&mt=204 This must be done when you buy a new button type key fob for the Alarm if you lose one.
I assume you know your personal entry code using the directional switches and the key switch to activate , if not , it's in the
Owners Manual
If you never set the code,the dealer can help you out here.
1. Set run switch to off
2. ign to acc
3. hold both turn sigs till lights flash
4. use
Left Turn Signal to enter number by pushing 7 times
5. use right turn signal as enter key
6. repeat until all 5 are entered and you hit enter
lights should flash and you should be OK.
KEY FOB ASSIGNMENT
The Key fob on TSSM motorcycles must be set so it will operate the alarm system on the vehicle.
This assignment must be completed with no pauses between steps greater than 10 seconds.
Turn the ignition OFF after all key fobs have been assigned.
The
programming mode will also exit after 60 seconds has elapsed without detecting any fob signup messages
or turn signal switch activity.
Two key fobs may be assigned to the TSSM.
The first successful attempt to program a fob will disable all previously assigned fobs.
If a second fob is to be programmed, it must be done in the same programming sequence as the initial fob.
Nov 16, 2013 | Harley Davidson Motorcycles
Nissan altima 1996, cabin fan blower switch works without the ignition key. If I forget to turn off the fan control switch it drains all battery.
Either the blower switch wiring has been altered, or you have a short to power in that circuit. The dash controls are not supposed to have power without the key. Are there any other functions that stay on with the key off? Stereo? turn signals? This would indicate a problem in the ignition switch, which is where all power must go through first.
Apr 21, 2013 | 1996 Nissan Altima
What could cause brake lights to work every now and then
I would check your brake light swich located under dash just fallow your brake pedle with a test light see if you have power going to it slitely press brake pedle see if other side of switch has power (key on car not running) if not try ajusting it by pulling on it or unscewing it if all checks out ok replace turn signal switch disconnect battery remove center part of steerring remove center bolt with steerring puller pull steering wheel with locking plate puller pull locking plate remove turn signal handle emergency button three scews holding turn signal under dash fallow steering colum disconect wires on right side (passenger side) tape a long wire to end of connector pull turn signal without pulling tape wire all the way out so you can tape it to new turn signal wire connector to be able to pull wires back down steerring colume (you might have to losen steerring colume and bracket two scews under dash four on steering colume)
Jun 27, 2011 | 1998 Dodge Ram 3500 2WD
After replacing my battery, I am unable to start the car without hitting the alarm reset under the dash. A mechanic told me to turn the key up to crank, quicfkly 5 times to reset. That did not work.
PLACE THE PROGRAMMED KEY IN THE IGNITION SWITCH. FOR THE FIRST KEY. TURN IGNITION SWITCH ON AND WAIT 3 SECONDS RETURN TO OFF POSITION AND REMOVE KEY. FIRST AND SECOND PROGRAMMED KEY OPERATIONS MUST BE PERFORMED WITH IN 15 SECONDS. INSERT SECOND PROGRAMMED KEY AND SWITCH IGNITION ON. WAIT APPROXIMATELY 10 SECONDS. ENSURE IMMOBILIZER WARNING LAMP BEGINS TO FLASH AND AN ACOUSTIC SIGNAL IS EMITTED.SWITCH IGNITION OFF AND REMOVE KEY.WITHIN 50 SECONDS INSERT NEW KEY AND SWITCH IGNITION ON.WAIT APPROXIMATELY 10 SECONDS.ENSURE ACOUSTIC SIGNAL IS EMITTED AND IMMOBILIZER WARNING LAMP REMAINS ILLUMINATED FOR 3 SECONDS INDICATING PROGRAMMING COMPLETE. FOR EACH ADDITIONAL KEY REPEAT PROCEDURE STARTING FROM THE BEGINNING.REPLACEMENT KEYS CAN ALSO BE REPROGRAMMRF USING DIAGNOSTIC EQUIPMENT.MAXIMUM 8 KEYS CAN BE REPROGRAMMED.
May 21, 2011 | 2005 Chrysler Sebring Conv
Installed new starter on 1999 chevy tahoe 5.7 and it tries to start without using the key
ONE OF THE WIRES ON THE STARTER IS ON THE WRONG TERMINAL. OR TWO OF THE SMALL WIRES ARE MAKING CONTACT WITH EACH OTHER. CHECK OUT ALL THE WIRES. HOPE THIS HELPS YOU. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 18, 2009 | 1999 Chevrolet Tahoe
Newly built computer starts up without using switch
No signal means, monitor has not been connected. (for crt s) and, on startup (for lcd s) . Easiest solution should be, PLEASE REMOVE AND PLACE THE RAM TIGHTLY AGAIN. i hope, it will solve the problem, if you have recently traveled with your cpu.
Apr 04, 2009 | Intel D915PGN Motherboard
Sangean ATS 818 AM/FM/SW Radio Logo
234 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
