Tally v7.2 educational error
Tally 7.2 runs in educational mode not enabling to edit entries.If any help provided to edit the Tally.ini file to enable run in full version.
    Guru:
  • 402 Answers
  1. You can make a system restore point while installing Tally. But before restoring the same point you should remember that you data can be lost in this process so take an external backup of your data on CD etc.
  2. You can go in back dates by changing system date and see if Tally is working or not (Some times it works !!).
  3. You can insure that your system name, lan cards etc. Doesn't change.
  4. If you know that a trouble is coming ahead e.g. you may need to upgrade system or format the system then best solutions is that you first surrender the tally before formatting.
  5. If you are in deep trouble an and cannot connect internet the surrender the tally in offline mode and keep that file in a pen drive or CD along with your data backup.
  6. If you are in much deeper trouble and finds out in the morning that you computer doesn't start windows and last option is to format it again, then try to start windows in DOS mode and recover that data files by copying whole Tally folder in to another drive. Then you can write mail to support@tallysolutions.com stating your Sr..No and contact person name to reset your licensing info. Wait for the response and then activate the Tally.
Thanks for using fixya.....
Posted on Sep 16, 2009
Ultimate Writing and Creativity Center isn't compatible with windows 7.
  1. You can run the software in compatibility mode. Read about that in the Windows 7 help file.
  2. If your copy Windows is authentic you may want to install Microsoft Virtual PC and XP Mode if they are still available on the Microsoft web site. Note that your hardware must be able to handle Virtualisation, and that feature is enabled in the BIOS.
  3. OR get a version that is compatible with Windows 7 32bits or Windows 7 64 bits (whichever you are running).
  4. OR install an OS that is compatible with your Writing Software.software. The last suggestion is done in jest.
Dec 14, 2013 | Computers & Internet
Ultimate Writing and Creativity Center is not compatible with my computer.
  4. OR install an OS that is compatible with your Writing Software. The last suggestion is done in jest.
0x8ac70013 msn video call are not working
Solution A: If you using McAfee Antivirus, the following steps will configure SiteAdvisor to stop monitoring windows live messenger. Go try solution B if you are NOT using McAfee Antivirus.
1. Navigate to the following folder:
Windows XP/2000/Vista (32-bit): C:\Program Files\McAfee\SiteAdvisor
Windows Vista (64-bit): C:\Program Files (x86)\McAfee\SiteAdvisor
2. Right-click on the file sasets.ini and choose Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini and restart your computer for changes to take effect.
Solution B: I am using XP with NOD32, using the latest version 2009 (Build 14.0.8117.416) and here is the solution that works for me,
1. Sign off and Exit messenger
2. Go to C:\Program Files\Windows Live\Messenger
3. Right click on file "msnmsgr.exe", select "Properties", a new window of msnmsgr.exe Properties will pop up.
4. Under "Compatibility" tab, look for "Compatibility mode", if the box "Run this program in compatibility mode for" is checked and show window 2000. Go ahead un-check it.
5. Open messenger again and try to test the video call.
Mar 18, 2011 | Home
My program file regsvr.exe delete.How restore this
Dear Amartya,
Here is a solution for your problem.
What the regsvr.exe virus does?
• This worm creates folders and a registry entry to enable its automatic execution at every system startup.
• This worm also creates a scheduled task to enable its automatic execution at a specified date and/or time.
• It also creates Autorun.inf file for its auto execution.
Solution to fix the problem:
1. If the task manager and registry editor is disabled then we need to enable them first. Read this post.
2. Delete the Autorun.inf file created by the virus. Read this post to know how to do that.
3. Now type msconfig in the Run dialog and click on startup tab.
4. Look for regsvr and uncheck any options, click OK.
5. Now traverse to control panel -> scheduled tasks, and delete the At1 task that might be listed there.
6. Type regedit in the Run dialog to open the registry editor.
7. Click on Edit -> Find and search for regsvr.exe
8. Just delete all the occurrences of regsvr.exe virus (do not confuse it with regsvr32.exe which is not a virus).
9. Navigate to entry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon and modify the entry Shell = "Explorer.exe regsvr.exe" to delete the regsvr.exe from it.
I think it helps.Let me know
Best regards
Chandrashekahr Bhat
Dec 25, 2010 | Microsoft Windows XP Professional
Tally hangs when we make entry
Just add this line to your tally.ini file:
sound= No
And it'll solve your problem immediately.
Sep 01, 2010 | Cameras
Vietcong game wont open,Backdoor Ranky keeps popping up.I know its not a virus,I am using win Xp home.Running ruddy awfull norton internet security 2008
It seems you have been infected by a trojan. This virus infects all versions of WIndows OS: It is considered a Low Risk Virus, but it needs to be removed immediately.
Backdoor.Ranky.Z allows unauthorized access on the infected pc by opeing a backdoor port.
Technical Name: Backdoor.Ranky.Z
Lets Remove the Virus:
  1. Disable your system Restore; this is to keep the virus from restoring itself to do this:
  • Right click on my computer
  • click on properties
  • select system restore tab
  • check "turn off system restore" uncheck "to turn on"
  • click Apply
  • click Yes when dialog box tell s you this will erase all restore points.
  • Press OK
2. Make sure your virus definitions are up to date.
3. Reboot your system in Safe Mode
4. Run a full/deep system scan & delete all infected files.
5. Delete/Modify any values added to theRegistry
how to edit registry
Delete this entry :
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run \"Advanced DHTML Enable" = "[PATH OF TROJAN EXECUTABLE]"
6. Exit registry editor and restart your PC.
7. Run a Full scan to make sure it is really gone.
Hope this helps (rate high if this helps)... Good luck! ^_^
Sep 17, 2009 | TOPICS Entertainment Vietcong 2
Tally Data Problem
EXITING TALLY!!
INCORRECT VERSION.
DATA OF INCORRECT VER.(10)
CAN ONLY RUN VERSION 9!
Jun 27, 2009 | Tally T2245 Matrix Printer
REGEDIT
regedit - to disable this file from running, delete it. if you want to turn off the registry, boot computer into safe mode (tapping f8 key while booting). if you need to manually uninstall a program, do an F3 search in the registry for the program name as a search string. there can be as many as 500 registry entries for the program... if you adopt the f3, delete, enter, f3, delete, enter, you may be able to uninstall the program's registry entry in as little as 15 minute to 1 hour... best of luck, I am not responsible if you delete a wrong value and crash your computer .... heheheeheheh.
Sep 26, 2008 | Red Hat Enterprise Linux ES 3 Standard...
Favourite game wont play on vista
goto properties of the file and in the compatibility tab enable "run this in compability for" and select the OS in which it used to work well... this might help....
Feb 14, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
827 people viewed this question
David Payne
David Payne
