Question about RCA Televison & Video
50 Inch RCA DLP TV won't turn on
Three weeks ago the lamp busrt and it was replace with phillips bulb from a repairman. After replacing the unit it worked for three weeks now nothing. No sign of life at all. Help? Any suggestions other then taking it to a repairman.
Jack
chrispurs1
  • 372 Answers
SOURCE: RCA 50" dlp lamp dead?
Hi. Most Dlp sets have a fan for cooling the bulb this should start at switch on if it doesnt bulb will not light. Check fan is pluged in & that blades can turn freely.
Posted on Sep 02, 2007
SOURCE: RCA Scenium HDLP 50
Sounds as though your tuner module is not working or you have a lack of signal to the tuner. You need to be sure that the set hasn't been switched to a different mode ( ie: from tuner to video..etc ). If all is correct in that matter, are you using a satellite dish. If you are infact using a satellite dish, then the signal strength from the satellite is not suffecient. ( you may need to realign the dish ). If you are on a cable signal ( cable TV ) you may have a bad input cable and need to call the cable company to check their input line. If all is well with the signals coming in, then infact, you may a bad tuner module in the TV. Good Luck
Ed NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
SOURCE: RCA DLP 50" NO PICTURE
MY 50 in RCA TV is making a clicking sound and there is no picture or sound it doesnt even seem to turn on i dont know what the problem is can someone pleace help
Posted on Jul 29, 2008
  • 17 Answers
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
ladywinn
  • 5138 Answers
SOURCE: 50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Posted on Apr 28, 2010
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
My rca dlp doesn't turn on
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
MY Samsung DLP Shuts off after 2 minutes than if I unplug it, it will come back on for 2 more minutes and than go out again. Could it be the Bulb and Ballast failing. I just replaced the bulb a few weeks...
try this..
On the bottom left corner there is a blue switch that detects if the lamp door is properly installed, if you try to turn your TV on without it won’t turn on.
Jan 31, 2010 | Samsung DLP HL-P5663W 56" TV
My 50 inch rca dlp tv will not turn on... the power light comes on but no sound nor picture. we had the bulb replaced about 6 mnths ago and and i know its not that. any suggestions?
Dont be to sure about LAMP,I have seen where NEW lamps can take nose dive, But try Ballast board that fires up Lamp,if it is Bad Lamp will not fire.
Aug 19, 2009 | RCA Televison & Video
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
White vertical lines in picture
It's not connections. On that particular unit I would suspect the Digital board, Samsung p/n# Bp94-02084a or the Dmd board. Have you ever noticed the picture freeze?
In any event, sounds as though you're going in the right direction having a tech test it out, it gets highly complicated...
Not sure why he replaced the lamp - but maybe he found it was about to expire.
Bill
Nov 14, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
472 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
