Question about Mtd Garden
Middle blade in 3 blade mower for ride on does not seem to cut?
I have early 90's MTD lawnmower with a 42" cut at 18 hp.
The mmiddle blade appears to either slip or not work at all.
This is a belt drive blade system. Is there something that I should be checking for. The blade is attached quite tight to the bottom of the mower deck.
    Novelist:
  • 133 Answers
Raise the deck and reach into the bad blade and try and turn it. If it turns easily then try to wiggle the blade up and down. If it moves up and down then the bearings are bad. You will have to remove the shaft and install new bearings. It is best to take it to a shop that can replace them. If you try and beat them off with a hammer you will probably mess up the shaft. I know from experience. You might be able to buy the whole new shaft with bearings already installed pretty cheap. Just find your part number and go to www.jackssmallengines.com and input the part number into the search box. They have reasonable shipping prices. You can also go to your local small engine repair shop they might even have free shipping.
Good luck and let me know if this helps.
thanks
roundo4
Posted on Sep 06, 2009
Testimonial: "Thank you that gives me a good idea where to start."
?setup for mower blades mtd 15-36rd is there left and right blade we need a diagram as shown how they are fitted give me a picture the blades ,the blades have wings at one end to allow the lawn go
I do not have pictures but will try to explain. There is no left or right for mower blades. Both the same.
It sounds like mulching blades you have That's ok.
The wings on the ends go in the up location.
If its a 36 inch cut then make sure the blades are 18 inch long each.
Make sure the blades are the same center as the old ones. Or they are made for that mower. If they are upside down you get a very bad cut.
Dec 26, 2016 | Mtd Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Removing lawnmower blades
check the belt that goes from each blade there is a timing mark on them
Aug 28, 2012 | Mtd Cub Cadet 33 In 344 CC Wide Area Cut...
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Where do i change the oil on 5.5 hp. 21 inch cut mtd push mower
Most of these machine will have an oil drain plug under the mower deck near the center of the blade. 80 to 90 % of them are a 3/8" drive female plug that can be removed with a ratchet and a short extention.
When you put it back in it is a good idea to clean it well and wrap the threads with 2 or 3 layers of teflon tape
Apr 04, 2010 | Mtd 22" Yard Machine Push Mower
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
What is missing on deck
Yes. All 3 blades should be the same size.
Apr 27, 2009 | Garden
Garden Logo
153 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
