Question about Samsung SyncMaster 713BM 17" LCD Monitor
Screen goes blank then displays Not optimum mode. recommended mode 1280x1024
  • 91 Answers
Change your screen resolution to 1280x1024 or lower than that.If that too doesn't work log on in safe mode and restore the system to an earlier time.
Posted on Sep 06, 2009
    Novelist:
  • 93 Answers
Hello !!
Welcome to Fixya.com
Right-click on an open space of your desktop and select properties. Select the settings tab towards the top of the screen. Use the Screen resolution slider at the bottom left until it diplays 1280 by 1024. Or conversely, you can click the Advanced button on the bottom right and then select the Adapter tab at the top of this new window. At the bottom of the window there will be a "List All Modes" button. Click this and select 1280 by 1024, True Color (32 bit), 60 Hertz. Either one of these should do the trick for you. Good luck!
Regard's
Anurag Shukla
I am getting an error message Not Optimum Mode Recommended Mode: 1280X1024 60Hz on my Samsung SyncMaster 913v monitor, what do you recommend to stop this message from occurring over and over again
If you are in windows, right click on your desktop in a blank area. On the drop down box that shows, click on Screen resolution (For Windows 7), properties (For Windows XP), or personalize (For Windows Vista). From there navigate to any tab or menu option to change video settings, or screen resolution.
There should be a slider bar to change the resolution you have, slide it to the 1280x1024 option and click apply.
I have included a video to assist further if I did not explain well enough.
May 23, 2011 | Computers & Internet
Screen goes black with a floating sign the says Not Optimum Mode Recommended Mode: 1280x1024 60Hz Took in for repair and work ok there
befor loding windows press F8 then choose vga mode
inside vga mode change the resolution to the recommended mode and restart your pc
then i think it will works
bye
dont forget to rate my solution
Jan 23, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Geen beeld opmerking :not optimum mode
comes on and screen says optimized mode 1280x1024 60hz i put it on and get no video
Jan 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Samsung lcd television the screen goes blank after 20 mins of watching there is still sound though
right click on your desktop.go to properties.then go to the screen saver tab.click on screen saver tab.then you will see call monitor power.click on the power icon.go to the settings forr home/office desk power scheme.there you will see a setting called (turn off monitor)change that.let me know if it did work hay.
Sep 07, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
New Samsung monitor returns only a blank screen when turned on. what can I do?
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Feb 04, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
My monitor has a message floating up and down saying not optimum mode recommended mode 1280x1024 60Hz what do i do
dear dalton,
1.right click on desktop.select properties and click it.
2.then select settings tab on top.
3.there u can see the screen resolution slider bar. there u can select the optimum mode for ur monitor.
thanks,
Sep 30, 2008 | Computers & Internet
I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'.
Sounds like you have an LCD monitor. LCD monitors look best in their native resolution. Yours must be 1280x1024. You need to (assuming this is a Windows PC) right click on the desktop and choose Personalize, Display Settings (Vista) or Properties, Settings (XP or older). Set the slider to 1280x1024. It'll confirm the change and then the message should never reappear.
Aug 28, 2008 | Computers & Internet
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Samsung 19" monitor 913n
screen has about 12 small opening page instead of a normal one page
Jan 11, 2008 | HP Pavilion dv9005us Notebook
Open Questions:
Samsung SyncMaster 713BM 17" LCD Monitor Logo
729 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
