Need to know how to access and clean or replace frigidaire atf7000fs0 front load washer filter
  • 1 more comment
  • rs1185 Sep 08, 2009
    How do I get the front panel off?
  • rs1185 Sep 15, 2009
    Need to know how to get the front off of the atf7000fs0 washer to replace the filter. The last reply was for a different machine. I see the two screws on the bottom as shown in the diagram supplied on the first thread, however, I do not see how to get the boot off or even if it needs to come off, whether there are other screws, etc? Does the control panel have to come off? Can this be done without having to pull the machine out or turn on its side, etc.??
    i beleive that this response and solution number two if for the wrong machine. Solution number one suuplied a manual for thecorrect washer. The second reply was for a different machine. My machine is about two years old, a stackable frontload and does not have a toe panel. The correct model number was supplied in the orginal request.
  • 5,911 Answers
There isn't a filter on this model Frigidaire washing machine. If you are referring to poor drainage issues, you need to access and clean out the drain pump. This is a simple process. Just follow these steps:
1. Unplug washer.
2. Locate and remove the screws that hold the toe panel in place directly below the washer door.
3. With the panel removed, locate the drain pump. It is located directly below the washer tub near the front of the washer.
4. Remove the large rubber hose from the inlet side of the pump (Its much easier to remove this fitting rather than removing the end of the hose that is connected to the wash tub).
5. Inspect the rubber hose for debris and inspect the impeller area of the drain pump. It is common for small articles of clothing to get lodged in the hose and restrict the drainage. It is also common for small items such as buttons, toothpicks, hair braids, etc. to get lodged in the impeller.
6. Next, remove the discharge hose on the right hand side of the pump and also check this area for debris. Clean the hoses and pump impeller thoroughly and re-install everything.
NOTE: You may want to drain any residual water remaining in the wash tub and drain lines PRIOR to removing any drain hoses. An easy method is to use a wet/dry shop vac and pull a vacuum on the drain hose. This will pull any water remaining in the washer and avoid any messy cleanups. If you do not own a shop vac, be prepared by lying down some towels to collect any water.
NOTE: It does not take much to damage these small drain pumps. If the preliminary steps do not solve your problem, you may have to replace the drain pump. The part number (if needed) is 137108100. Pcappliancerepair.com carries it for about $81.
If you are talking about poor filling issues, this may be an indication of a water inlet valve that has become clogged. Your inlet valve also includes the dispenser assembly. It can be accessed by removing the to panel of the washer and locating where the fill hoses are attached. The sediment screens in the valve can become clogged from sediment and rust over time. You can clean the fill ports by turning off the water supply and removing the fill hoses. Check the sediment screens inside the inlet valve and/or the fill hoses and clean with distilled vinegar to remove any sediment build up. If cleaning the valve does not solve the problem, a replacement part number is 134371220.
If you have any questions about these procedures, please let me know. I hope this helps you.
Posted on Sep 15, 2009
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell Sep 15, 2009
    For clarification: The screws that hold the toe panel in place are along the bottom front edge of the panel. There should be one screw on each side. Remove the screws and the panel will drop down, then come off.
  • Jeff Rockwell
    Jeff Rockwell Sep 16, 2009
    You are correct. I apologize for my oversight. When I reviewed the parts drawings it appeared there originally was a toe panel. Most of these small Frigidaire front loaders have a toe panel. Upon further review, I was wrong. You will need to remove the top panel of the washer, followed by removal of the front panel in order the access the drain pump. This will incude removing the rubber door bellow from the door facing to get the front panel free. If you have a dryer stacked on top of the washer, it will have to be removed in order to service the washer.
    Futhermore, upon review there is a small strainer basket inside the large inlet hose of the drain pump. You will need to remove the connection from the wash tub in order to get the strainer out to clean it. Again...I apologize for any confusion.
  • Jeff Rockwell
    It appears you will have to remove the control panel to access the top screws to the front panel. The door bellow, I believe, is glued in place on this model. It can be removed by inserting a putty knife behind it and carefully peeling it off the door facing (it can be resused). Reinstall using applaince cement to reseal. You can also use a good marine adhesive that is water resistant - do not use super glue. With the bellow removed from the door facing, push it inside the machine and disconnect the door latch connector(s). You may also want to remove the door. Remove the lower screws on the front panel, and it should come off, exposing the washer interior cabinet.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You can access the drain pump filter by following the procedure--
1. Disconnect the washer from the electrical supply, remove the front access panel.
Note: Some water will be left in the hoses and pump.
2. Disconnect the inlet sump from the pump.
3. Disconnect the outlet hose from the pump.
4. Remove the (2) screws, one on each side, holding the pump housing to the washer base.
5. Unplug the wires from the pump motor.
6. You’ll be able to see the pipe connected with the drain pump and next to this is drain filter. You can check this link for drain filter(Part #40)—
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995486346.pdf
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 06, 2009
  • 3,741 Answers
in your washing machine model there is no filters. click this link directly for all the trouble shoot in the washing machine http://www.applianceaid.com/frigidaire_frontload_washer.html ------------- this will help. please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 08, 2009
Filter replacement for frigidaire gltf2940es
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire GLTF2940ES Front Load Washer
How do I remove the bottom cover of my access pump tp check my Frigidaire front load washer GLTF2940e. It is not spinning. I need a visual! Thank You
The front panel does not open. HYou need ro access the pump from the rear of the washer or lean the washer to the side and access the pump from under the washer.
I hope the helps you. Please the me know if I can assist yuou further.
Thanks,
Vic
Apr 23, 2011 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Load washer will not drain nor spin? Help! Washer will start and water will enter unit, however clicking occurs and no spin of clothes.
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Mar 12, 2011 | Frigidaire Washing Machines
I have a Frigidaire Front Loader Washer Model # ATFB6000FSO which at times does not drain or makes a loud noise during draining. I believe I have a clogged water pump or filter. What is the best way to...
You need to lean it back and remove the lower panel, you will have complete access to the water pump, disconnect hose clamps,remove and clean the rubber boot,disconnect electrical connector and 2 screws holding pump, Replace with new pump, before beginning take pictures to ensure proper installation
Nov 19, 2017 | Frigidaire Affinity ATF7000E Front Load...
I need to know if there is a drain on the bottom of my washer that should be cleaned once a year
Most washers have a filter which needs to be cleaned often .unfortunately i am not familiar with your model
Jun 10, 2010 | Frigidaire Affinity ATF7000ES Front Load...
I have a frigidaire front load washer, it and the clothes stink.
I have read that using Nu Fresh in a few of your loads will take care of this problem.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Jul 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Wheres the model number?
ok the model number is on a silver plate inside the door or on one side of the machine. the outlet filter in on the pump you have to take the front bottom cover off and you will see the pump it is hooked to the drain hose screw off the filter that is on the pump it is a slot turn counter clock wise and then pull out and clean
Dec 18, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
