Question about LG Shine CU720 Cellular Phone
My LG shine keeps saying insert smartchip even though the sim card is in the phone. All my numbers are saved to the phone not the sim. Is there any way to get these numbers off the phone without the sim?
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
I have an lg shine from AT&T and yesterday it would not accept my sim card from AT&T. how do i fix it or is it fixable, i have seen several ppl complain about this very problem my sim card works in...
If your phone displays the 'Insert correct simcard' then your phone is currently locked to particular network. You need to unlock to use it with other network.
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Nov 23, 2010 | LG Shine KE970 Cellular Phone
Smartchip?
Phone is locked to other network.
smartchip=sim card
Jun 17, 2010 | LG KU990 Viewty
Phone not working.. Asking for smartchip
Sounds to me like your sim card is bad. Try wiping it off and putting it back, but you will most likely need to go get a new sim card.
Dec 11, 2009 | LG Shine CU720 Cellular Phone
My LG Vu today decided to say "Insert Smartchip" and I only have the "emergency" button available. I have tunred it around and around, and nothing works, any other ideas?
I had mine in upside down and that caused it to say insert smartchip.....could be a back sim card. If you have another phone test out the sim card in that phone or have your service provider help check the sim card
Nov 02, 2009 | LG Vu CU920 Cellular Phone
My lg shine says that it needs a smartchip but its already put in there, wat do i do?
Turn off the phone. Take the battery and Sim Card out. Make sure there is no dust or dirt of where the Sim Card goes. Blow air (from your mouth) of where the Sim Card goes. Sometimes rubbing a soft pencil eraser on the Sim Card contact points can help. Then place the Sim Card back in the phone. Make sure it is in the right position; copper contacts facing downward. Put the battery back in your phone. Turn it on, and see if the smartchip rejected goes away.
If not you may need to contact your Phone Provider’s Tech Support to troubleshoot and confirm that you may need a PUK reset code to register or you may need a new Sim Card, as they do fail from time to time.
Oct 17, 2009 | AT&T LG CU720 Cell Phone - Silver
I turn on my LG Shine cell phone and no matter
Oct 04, 2009 | LG Shine KE970 Cellular Phone
Insert smartchip
You are placing the smart chip on top of the smart chip holder. It's a little metal square where the smart chip should go. Lift up the metal square and place the smart chip underneath. I had to go to my local AT&T dealer to figure this out.
Jul 11, 2009 | LG Shine CU720 Cellular Phone
My lg shine wont read my smartchip at all.
My lg shine keeps saying insert smartchip and it sometimes wont let me text
You need to have your SIM replaced go to your carrier's store they will replace it for free usually
Jan 04, 2009 | LG Shine KE970 Cellular Phone
LG Shine CU720 Cellular Phone Logo
769 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
