Our TV seems to have no red color in it when we're watching Dish Network TV. However, when we watch a DVD or VHS video the color is just fine. We thought the problem may be with our Dish receiver and we had that replaced, but that didn't resolve the color issue.
  • 556 Answers
It could be the cables you are using to hook up the receiver.
Posted on Sep 09, 2009
How to connect nintendo 64 on a dish network tv
Can I connect my Nintendo to my Cable Box, my DVD, or my VCP (video cassette player)?
Your Nintendo system requires AV inputs to work. These products do not provide inputs. Connecting to them is not possible. Unless you get a blue plug for it to work then with the connection then.
Aug 01, 2012 | Nintendo 64 Console
I have a flat screen and Dish Network for my cable. I switched the "source" to watch a dvd, and when I switched it back to channel 3 I have a blue screen. cable (dish network) is on and working....
It all depends on how your dish cable is connected to your television. The possibilities I can think of would be by composite cables (not HD)--these cables are the yellow red and white combo. It could also be component--the video cables are the blue, green and red. The other possibility is a single HDMI cable which looks like a rectangle and delivers both the video and the sound from the cable source to the T.V. as one cord. Depending on which of these you are using to output the signal from the cable box to the T.V. will determine which "source" you should select when trying to watch tv. Hope this helps!
Aug 25, 2011 | Niko Televison & Video
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
Unable 2 watch dishtv in Benq LCD SD3731 with DVD cbl plugged in
The S_Video connection has precedence (most likely named AV1) over the RCA/composite one (better image quality - usually named AV2) so it will be automatically selected. If you want to view thru AV2 input you will have to select it manually every time you want it.
Jan 07, 2010 | Televison & Video
When i watch dish network my theater system wont work ,only if i watch dvd it works
I run my s video from the dish reciever to the tv/satillite s video input and the digital audio to the digital audio input on my reciever. The reciever is a sony V333ES and have no problems at all.
May 30, 2009 | Coby DVD-958 Theater System
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Daewoo dvd install
  1. Be sure that your VCR is a newer one with at least one "line in" set of jacks in the back. Some have one in the back and one in front.
  2. Your DVD Player should have a video/sound cable with 3 connectors on each end. Otherwise get one or 3 single cables.
  3. Connect DVD Video Out to VHS Video In (yellow).
  4. Connect DVD Left to VHS Left (white).
  5. Connect DVD Right to VHS Right (red).
  6. Turn on your DVD and VHS.
  7. Your VHS should have a tuner setting for "L1" or "L2". Select whichever shows the DVD's video on the TV.
  8. Remember to select that input channel whenever you want to watch the DVD.
  9. When watching a DVD, if you have a blank VHS in the VCR, you may record what you are watching onto the VHS, just as if you were recording from cable.
Verify these steps and you should be good to go ;)
Apr 19, 2008 | Daewoo DVDS151 DVD Player
Blue tent while playing movie
what type cables are hooked to the dvd, check and make sure that the cables are seated properly or chang the cables , could be the dvd player also
Feb 16, 2008 | Samsung LN-T4671F 46 in. LCD Television
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
