Question about HP PSC 1510 All-In-One InkJet Printer
My printer keeps wasting my color ink
I run a business that needs to print thousands of invoices. They only need to be black. No color needed. -- EVER-- yet my hp printer requires that I put in a color ink cartridge and then even though I only print in black it uses up the color ink anyway. This is a total waste of money. I actually CAN get it to work without the color cartridge when printing but then I HAVE to reinstall it anytime I want to copy or fax and then each time I have to reinstall it it requires a print cartridge alignment and then uses TONS of ink doing this. Can this be fixed so that I can continue to be an HP customer. Except for this I love my HP printers but I am tired of paying for color ink that I don't need
    President:
  • 1,865 Answers
The best answer is for you to buy a laser printer rather than inkjet. The laser printer will print at a lesser cost per page than the inkjet, and the color issue will be resolved
Posted on Sep 06, 2009
Black or color printer not printing new inkjet
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Jan 25, 2011 | Brother MFC 210C All-In-One InkJet Printer
Not printing all colours, heads clogged? Printing red and blue but not yellow.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. Make sure that the yellow ink is not empty. If it's not empty, head may be clogged.
If that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 11, 2010 | HP Photosmart D5160 InkJet Printer
Color stopped printing, changed cartridges, still will not print color. Now my black ink cartridge is acting up by starting off not completely printing text. What do I do now, buy a new printer?
Dec 06, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Black color will not print. Installed a new black
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon MP150 consumes color ink when ''Ink Cartidge'' = ''Black Only''
In order to keep the printhead free of clogs, all inkjet printers 'clean' the cartridges (color & black) fairly often. In my experience, a printer that is used regularly doesn't need 'cleaning' as often as it is done since this is an ink-wasting procedure and one that keeps the orders coming in for new cartridges where the vast majority of the profit is. Printers used only infrequently do have a tendency to clog and produce the poor quality we all hate.
Epson printers have ceramic printheads (the models I know) which will last just about forever providing they are used regularly. In home use, they have an ugly tendency to clog and often cannot be restored to their otherwise excellent performance. Printers using the integrated printhead/cartridge are easier to keep printing but this system makes the replacement cost much higher and the manufacturing cost slightly higher.
While HP hardware and consumables were made in the US (outside San Diego), I knew employees there and the early integrated cartridges cost a whole ~ 85 cents to produce and $20-$30 dollars to buy at retail.
Printing quality has unquestionably improved but it isn't likely to get any cheaper.
Dec 02, 2009 | Canon Office Equipment & Supplies
After cartridge change, the printer will not work
you might not like it, but here it is, it is the truth
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
Aug 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Color ink runs out too fast
See this link. Type "print using black ink" in the Search box and click the Search button. Select the appropriate option for your computer's OS. Note that you can only do this using plain paper. (I think the printer will still use a little color ink when doing print head cleanings. If you leave the printer powered on all the time, this will reduce the number of print head cleanings.)
May 19, 2008 | Canon BubbleJet i560 InkJet Printer
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
Why does it keep running out of color ink, while printing only Black and White?
Whilst you rarely print in colour, its important to know that you should try to print in colour at least once a week. This will reduce the risk of your colour nozzles blocking up.
Many people have gone out to replace their 'hardly used' colour cartridges when they dont work, thinking that they have dried up, when infact its simply blocked nozzles.
If you want to keep your colour nozzles and ink ready to run, just do a full colour alignment every 1-2 weeks. Minimal ink usage there and you keep your Canon MP780 running well!
Jan 12, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP PSC 1510 All-In-One InkJet Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
