Question about Acer Aspire 4730-4947 Notebook
How do i remove the lcd - Acer Aspire 4730-4947 Notebook
  • 50 Answers
For what? you will be remove the LCD. Have five connection. Coaxial cable, to inverter video, to camera, cable wifi antenna, and to microphone cable.
You must release all of connection. Make sure you release the screw in bottom case. May be six screw in there.
Posted on Sep 07, 2009
How to dismantle lcd of Neo Basic B3362n
A replacement screen maybe available from this WEB site.
www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Nov 30, 2012 | Computers & Internet
How to to disassemble replace lcd
Remove the plastic or rubber bumpers that are on the plastic square that goes around the lcd screen. Normally you will see them in the 4 corners and around the middle of the plastic strip. Remove them and you will see screws that you remove then the plastic square can taken off. Use a little pressure with your fingers to pry it off.
Next remove the screws on the side of the lcd that holds it to the brackets. Tilt the lid forward to let the lcd screen fall into you hand. Don't let it fall to far forward because there is a cable in the back of it that you don't want to damage. If the lcd does not come out, it might be held by screws in the backet near the 4 corners that you will have to remove.
Remove the LCD Cable from the back of the screen. It might have a piece of tape that holds it together where it plugs in that you can lift up. Then unplug the lcd from the lcd inverter at the bottom of the lcd (two cables that plug into the lcd inverter).
May 14, 2012 | Computers & Internet
How to do lcd disassembly
Replace display
remove the panel just below the lcd there you will see two screw remove them and there will be two connectors to the motherboard remove them then lift the LCD upward this will remove lock from the laptop next remove the four screw in the side of the LCD screen the plastic casing contains lock be careful while releasing the lock not to break the cover after removing the cover remove the screen just by lifting you will see a small PCB in the bottom of the LCD remove the connectors then replace the new display and do vice verse
Oct 27, 2011 | Computers & Internet
I own an acer 10.1"
it isnt that difficult actually , a how to for removing the lcd is shown here
Remove the four screw caps and screws from the LCD Bezel.
NOTE: The two center screw caps at the top of the bezel are for protection only.
Starting from the inside top edge, pry the bezel away from the panel. Continue moving down the sides until the bezel is removed. If necessary, use a plastic pry to release the corners of the bezel.
1063_66_97.jpg 4. Lift up the bezel and remove it from the LCD Module.
IMPORTANT: If the LCD Bezel is replaced, remove the lid sensor magnet from the bezel, and attach it to the replacement bezel.
  1. Disconnect the cable from the Camera Board as shown.
1063_66_99.jpg Remove the Camera Board from the LCD Module.
  1. Remove the four securing screws (two each side) from the LCD Panel brackets.
1063_66_104.jpg Turn the LCD panel over on a clean surface. Remove the adhesive strips securing the LCD cable.Carefully lift the adhesive tape securing the cable connector to the LCD Panel.
1063_66_105.jpg 5. Hold the adhesive tape clear of the LCD Panel and disconnect the LCD cable as shown.
  1. Remove the adhesive strips holding the MIC cable in place.
1063_66_107.jpg 3. Remove the MIC Board from the LCD Module.
  1. Remove the adhesive strips holding the Camera cable in place.
  2. Remove the Camera cable from the LCD Module.
  1. Remove the adhesive strips holding the Antenna cables in place.
1063_66_110.jpgCarefully pry up the Antenna pads, as shown, and remove the pads from the LCD Module. IMPORTANT: A strong adhesive is used to secure the Antenna pads in place. Take care not to bend the pads during removal.
to fit a new one do the steps in reverse
If you found this info useful Please vote for me
Apr 05, 2011 | Computers & Internet
I am in need of a repair manual for a Toshiba Satellite L455-S5975 laptop in order to replace the LCD screen. I have searched everywhere, but no luck. Does anyone have a source? Thank you.
Not sure if you will find one... Process on toshibas is:
Pop top cover (sometimes also secured with a few screws on side or bottom of laptop) near monitor base above keyboard to access LCD cable and mount screws
Unplug cable and remove monitor mounting screws (Under plate, on back where cables plugin, and sometimes on bottom)
Take monitor (on flat surface) and remove screw covers with needle so you can put them back on later.
Remove all screws
Use plastic credit card and run around outside lip of screen case until removed
Remove LCD mounting screws
Remove LCD and inverter
Remove LCD brackets and inverter from panel
Replace panel and start working backwords.
Mar 31, 2011 | Toshiba SATELLITE L455-SP5016M LAPTOP LCD...
How to open Laptop LCD
  • Shut down the laptop. Disconnect the power cable, close the LCD screen, and place it face down Push down on the battery, and slide it to the left & Lift it out of its compartment,
  • Grip the black tab from the hard drive. Slide the hard drive to the left and up, Remove the three screws from the top edge of the laptop on the bottom casing. Flip the laptop over, and open the LCD. Press down the "Insert" key, and then insert a flat-head r into the right side of the button panel between the keyboard and LCD screen. Pry up the button panel. Do not remove it from the laptop completely.
  • Remove the four screws from behind the top row of keyboard keys. Lift the keyboard out, Disconnect it
  • Close the LCD, and place the laptop face down. Remove the screws securing the RAM and wifi card cover. Disconnect the two antenna cables from the card. Remove the single screws,
  • Place the laptop face up, and open the LCD. Locate the LCD cable from the left side,. Disconnect the cable from the motherboard.
  • Remove the two screws from each LCD hinge. Lift the LCD screen panel off of the laptop,.
  • Remove the remaining 11 screws.
  • Locate the track pad ZIF cable above the track pad area & Disconnect
  • Aug 10, 2010 | HP Pavilion dv4000 Notebook
    How to change out a broken lcd screen on an aspire
    http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
    This is its contents without the pictures:
    OK, let’s get inside the display assembly.
    First of all, turn off the laptop, unplug AC adapter and remove the battery.
    The screen bezel* has four screws hidden under for seals. Two rubber seals on the top of the bezel and two plastic seals on the bottom.
    You can remove all four screw seals with a sharp object as it shown on the picture below. Glue removed seals somewhere on the bezel so they don’t get lost.
    Remove four screws found under seals.
    Start remove the screen bezel with your fingers. Proceed slowly while removing the bezel.
    Carefully separate the display cover from the screen and access the LCD cable connector
    You’ll have to unplug the LCD cable from the screen.
    First, unglue the clear sticky tape securing the connection.
    Second, unplug the LCD cable from the connector on the screen.
    Here’s how you can remove the LCD screen.
    Simply remove four screws securing the LCD screen to the display hinge. Remove four more screws from the other side of the screen.
    Now you can remove and replace the LCD screen with a new LCD screen.
    Put all the screws back in there places
    Dec 31, 2009 | Acer Aspire One PC Notebook
    Monitor broke
    Go to Ebay, (Computers and Networking>PC Components>For Laptops and Notebooks>Screens,LCD Panels>Emachines D620)
    Or here is a website I found,
    http://www.screentekinc.com/eMachines_D620-5777--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
    Here is information on removing the old LCD screen,
    http://www.sparepartswarehouse.com/LCD-Removal/laptop-lcd-screens-repair-removal-instructions.asp
    Another one,
    http://www.screentekinc.com/lcd-removal-instructions.shtml
    Jul 19, 2009 | eMachines eMD620-5133 Notebook
    How do I remove the display panel from an Acer 3000 series laptop?
    Remove the 3 screws at the Base of the Screen, Open the Screen all the way horizontally, and Take off the Trim Piece covering the Buttons. Remove the Cover to the RAM/Wireless Bay, and remove the Two Wires on the Wireless Card. (Be Sure to Close the Laptop before you remove the either the Upper Trim Cover or the RAM/Wireless Bay Cover.) Remove the Keyboard, and pull the Wireless Antenna Cable through the Case and out of the Machine. Remove the Ribbon Cable from the Motherboard, and remove the 4 screws securing the screen to the rest of the Laptop. installation is reverse of Removal.
    Jan 17, 2009 | Acer Aspire 3000 Notebook
    Acer Aspire 4730-4947 Notebook Logo
    Mohammed Ebrahim M
    Mohammed Ebrahim M
