Question about HP PSC 1510 All-In-One InkJet Printer
Aligning my printer keeps wasting my ink
Everytime I install a new cartridge my HP printer REQUIRES a cartridge alingment that wastes TONS of ink. My cartridges have never been out of alignment and would only need an alignment if they were out of alignment. I can not locate any preference that allows me to turn this function off. So how do I do it? If I can not, WHY NOT?
Changed cartridge, received a code "P", says to install a new cartridge, but I just did install. Will not allow to do a clean print head.
hi, first turn the printer off and unplug it and let set for 30 mins. Ig that doesn't work try taking the cartridge out and reaching inside where you put the cartridges go and clean the print head with alcohol with a q-tip.
Nov 22, 2015 | Epson Picturemate Picture Mate Deluxe 500...
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
My HP photosmart c4280 keeps aligning the cartridge when on!
probably the alignment its not succeed
be cause on of color is missing
check if you see and the 4 colors on paper (yellow cyan magenta black)
if one color is try cleaning , refilling or replacing the cartridge
if you need instructions for refilling check here
http://www.youtube.com/watch?v=Ybj4awp_1ic
May 01, 2010 | HP Photosmart C4240 All-In-One InkJet...
The Check Your printer light keeps coming on. I
did you change the cartridges with O.E.M. or aftermarket? If with O.E.M inks then there is a problem with the waste ink container and it needs to b cleaned.. requires removal of the waste in station which is under the inks on the right side of the printer
Mar 31, 2010 | HP PSC 1350 All-In-One Thermal Printer
My printer keeps printing the test page everytime its switched on, How do I stop this as wasting ink ?
Remove and reinstall the printer driver. Make sure you have the latest driver consistent with your operating system. www.hp.com/support
Feb 24, 2010 | HP PSC 1315 All-In-One InkJet Printer
My printer keeps wasting my color ink
The best answer is for you to buy a laser printer rather than inkjet. The laser printer will print at a lesser cost per page than the inkjet, and the color issue will be resolved
Sep 06, 2009 | HP PSC 1510 All-In-One InkJet Printer
Installed new ink cartridge get a page of stuf
you must replace all ink carts at the same time for a sucessful alignment
Jan 25, 2009 | HP PSC 1315 All-In-One InkJet Printer
My C3100 HP all-in-one printer prints a test page everytime I want a single copy. How can I print before wasting ink on a test page?
cannot load new ink cartridge c 3150 black cartridge keeps popping out when you close acces door help thanks harry
Apr 23, 2008 | HP Office Equipment & Supplies
Printer Not showing all colours
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 11, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer Problems
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
- unplug cable
- plug cable
Run the software.
oke
Oct 20, 2007 | Canon PIXMA MP160 All-In-One Printer
HP PSC 1510 All-In-One InkJet Printer Logo
131 people viewed this question
Seeker5211
Seeker5211
