Question about Kenmore 24032\24036 Top Load Washer
My Inglis washer also gets stuck on rinse
My washer machine gets stuck on the rinse cycle. The machine will try to fill up but it seems the water just runs out.
  • 15,935 Answers
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Washer fills on wash won't fill on rinse. Does on old washer and new washer. Checked and plumber said not the plumbing. Help PLEASE
It seems that you are out of cycle; meaning you are washing on rinse phase and the you are not getting water on rinse because you are at the end of the cycle. Try this; set the washer to the end of the rinse cycle, let it spin and stop. then wait 1/2 hour then start a wash you will be at the beginning of a new wash cycle..
Nov 10, 2016 | Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
New inglis washer expells water when fills
seems like no one wants to send you any love Richard. Well fear not, if you haven't figured this out yet, I'll do what I can. It seems to me that you have the drain hose lower than the top of the wash basket or a hole in that hose. If the drain hose is too low, the water will run out of the machine due to low center of gravity. Ideally, 6" above the level of the tub is sufficient. If there is a hole in that hose, replacement is pretty straight forward.
Jul 18, 2009 | Whirlpool Inglis IP4400 Washer
Will not go through the rinse cycle not filling
your cold water is turned off  if you check its not than where the hose connects to washer for cold water disconnect it and make sure its clean in the hose and the part of the washer it connects to  there might be rust if it is clean than you need a new water valve
reply if u got questions
Jun 06, 2009 | Danby DWM99W Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool ingis washer will not engage rinse cycle
make shure the cold water is on and also if it worked before then it cold be two parts 1 the timer is bad or 2 the water inlet valve
Jan 17, 2009 | Whirlpool Inglis IP4400 Washer
Kenmore 24032\24036 Top Load Washer Logo
423 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
