Question about HP Photosmart C5180 All-In-One InkJet Printer
How to take apart a HP C5180 Printer. I got two broken HP printers, but with differant issues. I want take them apart and replace the circuit board from one into the other. Getting it apart so far has not prove that straight forward. Any place to get instructions would be helpful.
I am having been looking for the cable that connects the upper portion to the base. If you have it in the printer you dont need, i am willing to buy that cable off you. There are actually 2 cables.
Posted on Dec 15, 2009
My HP photosmart C5180 jams paper too often; why would that happen?
Hi
Please follow the link below to get the issue resolved
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00702180&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N1058
If the issue still persists then you might have to replace the printer
Hope it works for you
All the best!!
Regards
Nov 21, 2010 | HP Photosmart C5180 All-In-One InkJet...
PHOTOSMART C5180
the ink cartridges are stuck st one side of the printer - how do I take the printer apart to take out the cartridges?
May 14, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP C5180 photosmart keep turning off and on. Will
This is due to ON/OFF switch is having the issue. Repair/replace the switch with the help of expert engineer/service center experts will resolve your problem.
Revert back for more assistance.
Jan 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP C5180 error messsage Oxc19a0024 will not print. what to do.
Ok this is a old postint but you may come back to see it or it may be handy for some one elles.
Solution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
  17. All the best: Pineworks
Jun 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
How to reset the ink level on a HP C5180
You have to purchase new inks. If you have refills, it will not detect the ink levels due to the chip on the ink cartridge. When inks have been refilled, There is no way to reset the chip.
Feb 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
C5180 Ink System Failure CodeOxc18a0206
Here is what you can try:
1. Turn off the power and unplug it from power source.
2. Open the right side of the printer (looking at the front).
3. Disconnect, by pulling gently, both white flat ribbon cables off the main circuit board.
4. Plug in the power source and turn the printer on. Wait till you get a error message and push "OK".
5. Unplug the power source.
6. Reconnect the flat ribbon cables by aligning and carefully pushing them into the conectors on the main circuit board.
7. Plug in the power source and turn the printer on (Printer preparing occurred).
8. The 0xc18a0306 error should now be gone.
http://www.fixya.com/support/t5587774-hp_photosmart_c5180_ink_system_failed
Feb 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP bought in Europe, and North American cartridges not working
you would need the logic board replaced which would exceed what the printer is worth,
Feb 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
MY c5180 printer wont print w/black ink works fine in color
there is a circuit opposite to the cartridge exactly if that cable which has this circuit it causes exactly the same problem what you r facing at present. if the printer is ubnder warranty send it to the hp service center for free repair or may be replacement. but if not under warranty contact local technician as it will not be too costly at local repair center.but if you send it to ho service center for reparing if its without warranty that it will cost u very much for this.
Jan 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP C5180 "wrong cartridges" error
try this semi full reset
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Dec 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
1,394 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
