Question about Whirlpool MH3184XP Microwave Oven
I have a MH3184 XPS Whirlpool microwave that is not displaying anything on the display. I changed out the over the stove light bulbs on this unit. One of them broke while I was changing. I then noticed that the display was dead. I have checked and the unit has voltage to it ? Help!!!
  • joverstre180 Sep 07, 2009
    Checked all three fuses. They do not seem to be blown. Can one of these small ceramic fuses be bad with a reading of 6 ohms and dropping while It is being checked?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This might have happenned due to a blown fuse on the control board. There are 3 fuses in this microwave. Check for a little ceramic fuse that is in line after the big fuse which is connected to the main line. The fuse if located on the right front panel. There is also another ceramic fuse in the microwave. You'll need to check these fuses if they are fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 06, 2009
  • Rylee Smith
    Rylee Smith Sep 08, 2009
    Yes as advised earlier the little ceramic fuse which is in line after the big fuse on the right front panel can be bad and needs to be replaced.
    Thanks
    Rylee
How do I fix stove top lights?
Find the manual online by going to Google and put in the make and model of your stove. It's usually found on the inside of the door. In the manual it will tell you how to replace the lights (bulbs).
Oct 12, 2014 | Whirlpool MH6130XEB/Q Microwave Oven
The night light switch on my maytag over the range microwave will not work
I am assuming you changed the bulb. Anything that sits over a stove will become mucked up with grease and cooking oils etc. That can prevent the bulb from seating in the socket, the switch from making contact, etc. Unplug the unit, remove the bulb and get int here to clean the grease out. That should fix it.
Nov 03, 2013 | Microwave Ovens
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 08, 2010 | Kenmore 80599 Microwave Oven
How do I change the light bulb in the microwave - the one that shines above the stove? I removed the covering and tried to remove the bulb but it doesn't seem to unscrew and the bulb just came out - no...
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "how to change cooktop lamps" for example.
Nov 24, 2009 | Roper MHE14XKB Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Accubake Microwave Oven 2001 vintage.
Hello jparks739,
Please find a link to an exploded view of you micro as well as details on how it goes together. Note the two screws ( item 31) that hold the cover and lens over the bulb in this document.
Hope this helps you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 03, 2008 | Whirlpool GH5176XPT microwave Oven
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
No installation Instructions or Owners Manuel
Although you gave an incomplete model number, Owners Manuals, Installation Guides, Warranty Guides and Part Lists can be found for the entire MH3184 series on this page: Whirlpool Product Literature/MH3184 Series
Hope this helps!
Aug 05, 2008 | Whirlpool MH3184XP Microwave Oven
Whirlpool MH3184XP Microwave Oven Logo
108 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
